Hey guys,
After spending a few days trying to build my DSDT for my Hackintosh, I've given up and I'm turning to the experts.
At the moment, I'm running on a laptop with the following specs:
Intel Core i5 2450M (Sandy Bridge)
Intel HD 3000 Graphics
Motherboard:
Manufacturer Hewlett-Packard
Model 1793 (CPU1)
Version 0692100000204710000620100
Chipset Vendor Intel
Chipset Model Sandy Bridge
Chipset Revision 09
Southbridge Vendor Intel
Southbridge Model HM67
I'm trying to build a DSDT using the DSDT Editor, but I'm getting errors left and right.
I'm trying to accomplish the following:
- Backlight Control (At the moment I can't control the brightness of my hackintosh)
- Sleep (It's buggy, and doesn't really work)
- USB 3.0 ports are also buggy. (Crashes if ports are plugged in at boot, and after boot only USB 2.0 devices work.)
I fixed most of my other issues with kexts and such.
Any help would be greatly appreciated.
Attached is my DSDT. It's the original copy, and hasn't been modified at all.
DSDT.zip
@eddiewang
try this one
HP bios sucks
read and apply
http://Olarila.com/forum/viewtopic.php?f=27&t=1716
http://Olarila.com/forum/viewtopic.php?f=18&t=1703
I agree, HP sucks. I want to replace the wifi card in the future, but I heard you can't, because BIOS is locked and whitelisted.
Anyways, I applied the DSDT. It works wonderfully, sleep and USB 3.0 working great now.
I have 2 big issues though:
1. Audio no longer works. I had to delete VoodooHDA.kext in order to boot up (otherwise there is a kernal panic.) At the moment, the audio shows mute, and I can't change it. (Picture showing it in attachment.)
2. Brightness settings WORK! However, it's weird, there are only 4 levels of brightness I can change. Meaning the slider or buttons don't make a difference until the last 4 squares. (I've attached another picture to show when the laptop is at its brightest settings.)
Pictures: http://imgur.com/a/ZEENQ
Thanks again for your help!
i apply in dsdt
hdef layout 12 (0C) for applehda...
if u have it remove from system/library/extensions
or use applehdadisabler, for future system updates don't have problems with applehda
or try this one without injection of layout 12 and should work u voodoohda
Thanks! I will get on that now. Do you have any ideas on how to fix the brightness bug?
You deserve a medal for your awesomeness. 8-)
EDIT: PS. This isn't related to the DSDT (or is it) but my VGA out port doesn't work. (I would like to connect to an external moniter.) There's no chance of that is there :(
take a good read here (use google translator) portuguese > u language
http://Olarila.com/forum/viewtopic.php?f=3&t=725
hey artur, just an update.
I got almost everything working now :)
I just have 2 more things i'd like to inquire about.
The first is the mute "red" light doesn't come on when it's muted. Is there a fix for that? Also, the brightness keys do not work. Instead, I have to set it to another key (like fn+f2 and fn+f3).
My main problem now is that there is a kp when I remove NullCPUManagement. Do you know how I can remove it without the system crashing at boot?
Thanks.
Eddie
just noticed this thread is still active
would you please post your kexts and chameleon plist file?
i'm running dm4-3050us (identical), cant get it to boot without unishit
i barely got setup going by finding a patched ahci kext for the installer
http://www.osx86.net/guides-tutorials/19064-guide-getting-osx-installer-recognize-your-hard-drive.html
after that i'm pretty much stumped
thanks.
Hey, which kexts would you be looking for? Mine is pretty much a vanilla install. I don't want this thread to be filled with another person's problems, so if you open another thread and link it here, I'd be glad to help. :)
about power management...
probably must use a proper ssdt for u cpu and patch appleintelcpupowermanagement
http://Olarila.com/forum/viewtopic.php?f=28&t=1703
some hp must use lapic_kernel or with chameleon a module call kernelpatcher.lyb to eliminate that error...
about the other things don't know another solution..
thanks.
I have the same laptop can you or someone else tell me how i would go about hackintoshing it? im a bit of a n00b but i do have experience in working with computers just not with hackintoshing, so any help would be greatly appreciated :)
