I'm trying to install this Mountain Lion poratile
DELL VOSTRO 3560
At this time I managed to get it started, I would like to operate the audio
by SystemInfo downloaded from Olarilla I saw that the audio is compatible, but I can not make it work.
SystemInfo as hardware AUDIO Codec I get the following:
V ID: 8086
D ID: 1e20
The same Hardware with Hardware/Manager on Win8 i get this codec
V ID: 8086
D ID: 2806
DSTS DEL VOSTRO 3560
DEELVOSTRO.zip
u can if u find one patched for u codec...
I am trying to activate my card Intel HD 4000 from DSDT.
EFI string with my intel is activated through this code
ig-platform-id: 01660003
<key>device-properties</key>
<string>7f0000000100000001000000730000000200000002010c00d041030a000000000101060000027fff04002c0000004100410050004c002c00690067002d0070006c006100740066006f0072006d002d006900640000000800000003006601140000006800640061002d0067006600780000000d0000006f6e626f6172642d31</string>
I tried this change in DSDT
               Store (Package (0x0E)
                       "device-id",
                       Buffer (0x04)
                            0x66, 0x01, 0x00, 0x00
                       "vendor-id",
                       Buffer (0x04)
                            0x86, 0x80, 0x00, 0x00
                       "model",
                       Buffer (0x1E)
                           "Intel HD Graphics 4000 Mobile"
                       "AAPL,ig-platform-id",
                       Buffer (0x04)
                            0x04, 0x00, 0x66, 0x01
                       "VRAM,totalsize",
                       Buffer (0x04)
                            0x00, 0x00, 0x00, 0x18
                       "hda-gfx",
                       Buffer (0x0A)
                           "onboard-1"
                       "AAPL00,DualLink",
                       Buffer (0x04)
                            0x01, 0x00, 0x00, 0x00
                   }, Local0)
               Return (Local0)
The video card is recognized , but I have the laptop video separated into 4
Delete this part
                       "AAPL00,DualLink",
                       Buffer (0x04)
and the package size
Store (Package ()
Actually you only need the AAPL,ig-platform-id
http://Olarila.com/forum/viewtopic.php?f=3&t=1583
Thank you for your answer.
For my intel hd 4000 it has is platform-id: 01660003
My patch on DSDT is correctly
               Store (Package ()
                       "device-id",
                       Buffer (0x04)
                       "vendor-id",
                       Buffer (0x04)
                       "model",
                       Buffer (0x1E)
                       Buffer (0x04)
                            0x03, 0x00, 0x66, 0x01
                       "VRAM,totalsize",
                       Buffer (0x04)
                       "hda-gfx",
                       Buffer (0x0A)
                           "onboard-1"
                   }, Local0)
               Return (Local0)
only the ones u need
see in dsdt patches ivy bridge section.
this is u edited dsdt with all usual patch for ivy, now insert in there what u want (specific, like hd 4000) hdef is layout 12 for sound , must search for the right one for u.. is only edited with the bases, if u gonna use a applehda with layout 1 must change from 12 to 1
DSDT.zip
[attachment=0]DSDT.zip[/attachment]
I understand it, this is the my DSDT Dell with all the most common changes?
have I to add only the Intel HD 4000 and the audio?
Please , I need Help
Because if you boot with Clover in UEFI mode the audio suffers the disorder Effect Laser, and if I boot with Chameleon audio is Ok ?
Do you know if there any way to get my Wifi card ?
Broadcom
V: 14E4
D: 4365
about audio give + info
what are u using
clover config (why u don't post that question in clover topic, maybe slice answer to u question )
wireless
http://www.insanelymac.com/forum/topic/51725-broadcom-bcm43xx-wireless-driver-beta/
i don't know if it works...
but that issue is well know , broadcom only few cards work without problems in mac os x...
why u don't change the wireless by a compatible one ?
