If I put my DSTS ,
do you me patch the speedstep , so i can delete nullpower...kext ?
I've tried the script on the forum but did not work ( Intel I5 2450 SnBr Hz 2,5 Turbo 3.1 )
Please Help Me ,
Thank you
is only to run 2 scripts, generating the ssdt
and the other to patch the kext...
the solution is that ones
have u set in org.chameleon
dropssdt=yes
p and c-states=no
In chamaelon I set Dropssdt = yes
But I did not understand I have to change
before
   <key>GeneratePStates</key>
  <string>Yes</string>
  <key>GenerateCStates</key>
after
  <string>No</string>
  <string>No</string>
Now my Chameleon is :
<key>DroppSSDT</key>
<string>Yes</string
the settings
  <string>No</string>
  <string>No</string
<string>Yes</string
and read, read a lot about what are doing
the guides are made to read, a lot a people give hours to do it
hack in mac os x is 99% of reading, googling, persistency and 1 % of luck u hardware is compatible
I'm sorry, you're absolutely right
Chameleon can generate P and C states automatically, simply enable the options
Code:
GeneratePStates
Yes
GenerateCStates
Yes
but I understand the opposite.
I apologize to the forum
Thank you for your patience
This evening I'll try
Are you sure AICPM was patched correctly? Copy/paste the patcher output.
I think so, It gave zero errors I used AICPAPatch
This evening when I'll at home still apply the patch and tomorrow and post the result
Thanks for everyone's help and sorry for my english
