biasaf Posted September 18, 2012 Posted September 18, 2012 Motherboard: CPU Type: DualCore Intel Core i5, 2933 MHz (22 x 133) Motherboard Name: Hewlett-Packard HP Pavilion g6 Notebook PC Motherboard Chipset: Intel Ibex Peak-M HM55, Intel Ironlake-M I generated a DSDT file using DSDT editor, and now I'm trying to find the right DSDT patches to hopefully fix sleep problems. I couldn't find my laptops motherboard in the 'DSDT by motherboard' page so I'm posting this... I did, however, find a DELL laptop which holds the same motherboard chipset (almost): Intel Ibex Peak-M HM57, Intel Ironlake-M (DELL Inspiration N5010) Let me know if additional info is required.
artur-pt Posted September 18, 2012 Posted September 18, 2012 hi try one the generics nehalem for the hp good hack PB Easy Note TM 86 - i5 430 M - H55M - Ram - 6 GB - Alc272 - Radeon HD 5470 512 QE/CI Lenovo G500 - i5 3230m - HM77 - Ram - 8 GB - Conexant audio - HD 4000 My OS X Files
biasaf Posted September 19, 2012 Author Posted September 19, 2012 Thanks. I tried what you suggested and tried to apply the patches on my dsdt. Problem is when I compile and try to save the dsdt file, it comes out BLANK and the patches don't even apply... Here's my dsdt and the patch I tried to apply, could you please try it and tell me what's wrong? What I'm trying to fix is: Sleep, brightness and Battery. Archive.zip
artur-pt Posted September 20, 2012 Posted September 20, 2012 hi the dsdt is already edited about u want is specific patches for that model u must try to search and apply what can i say brightness and sleep several notes don't work at all about battery u use a kext like this http://www.osx86.net/downloads.php?do=file&id=1384 or http://www.insanelymac.com/forum/index.php?showtopic=264597 good hack PB Easy Note TM 86 - i5 430 M - H55M - Ram - 6 GB - Alc272 - Radeon HD 5470 512 QE/CI Lenovo G500 - i5 3230m - HM77 - Ram - 8 GB - Conexant audio - HD 4000 My OS X Files
biasaf Posted September 20, 2012 Author Posted September 20, 2012 I see... Does brightness work for you? I could live without sleep... even though it's annoying to have to shut down and book and boot it everytime.. but my battery is really short with brightness on max.. and its annoying...
artur-pt Posted September 20, 2012 Posted September 20, 2012 hello mine works good but mine is not intel hd 3000 some people use a kext to brightness http://www.insanelymac.com/forum/index.php?showtopic=236835&hl=brightness&st=0 see there if any solution good hack PB Easy Note TM 86 - i5 430 M - H55M - Ram - 6 GB - Alc272 - Radeon HD 5470 512 QE/CI Lenovo G500 - i5 3230m - HM77 - Ram - 8 GB - Conexant audio - HD 4000 My OS X Files
rivaldo Posted September 21, 2012 Posted September 21, 2012 Artur, Saudações do Brasil. Vc. fez seu hack em um HP G6? Poderia me ajudar com isso? Grato e SDS Rivaldo Ribeiro rivaldo.ribeiro@gmail.com
artur-pt Posted September 21, 2012 Posted September 21, 2012 olá meu note é um Packard Bell é o do assinatura. ajudar tamos aki para isso. bom hack PB Easy Note TM 86 - i5 430 M - H55M - Ram - 6 GB - Alc272 - Radeon HD 5470 512 QE/CI Lenovo G500 - i5 3230m - HM77 - Ram - 8 GB - Conexant audio - HD 4000 My OS X Files
rivaldo Posted September 21, 2012 Posted September 21, 2012 Então amigo. Eu consegui fazer um hackintosh em um desktop HP 666, i3 usando o IATKOS L2 e adorei. Me animei e queria fazer em meu notebook HP G6 1c55ca. Poderia me ajudar pq. não consigo iniciar a instalação. SDS Rivaldo
artur-pt Posted September 21, 2012 Posted September 21, 2012 olá posta teu hardware, atualiza no teu profile, tua assinatura, qualquer coisa como tenho no final da minha resposta e já agora porque estás a postar na secção inglesa do forum... bom hack PB Easy Note TM 86 - i5 430 M - H55M - Ram - 6 GB - Alc272 - Radeon HD 5470 512 QE/CI Lenovo G500 - i5 3230m - HM77 - Ram - 8 GB - Conexant audio - HD 4000 My OS X Files
rivaldo Posted September 24, 2012 Posted September 24, 2012 Vou instalar o Windows nele para poder usar o AIDA e colocar as informações de hardware no meu perfil. Postei aqui pq estava pesquisando na internet sobre o HP G6 e achei esse post, qdo. vi seu perfil e percebi que eras português e mantive contato. Acabo de add como amigo, espero que não se importe. Grato e SDS Rivaldo Ribeiro
artur-pt Posted September 24, 2012 Posted September 24, 2012 olá para veres teu hardware podes usar isto http://Olarila.com/forum/viewtopic.php?f=6&t=25 bom hack PB Easy Note TM 86 - i5 430 M - H55M - Ram - 6 GB - Alc272 - Radeon HD 5470 512 QE/CI Lenovo G500 - i5 3230m - HM77 - Ram - 8 GB - Conexant audio - HD 4000 My OS X Files
rivaldo Posted September 25, 2012 Posted September 25, 2012 Acabo de colocar o hardware, verifique se ajuda as informa;óes. Grato Rivaldo
rivaldo Posted September 25, 2012 Posted September 25, 2012 Vou postar aqui pois náo aparece na minha assinatura. Processador Mobile DualCore Intel Core i3-2330M, 2200 MHz (22 x 100) Nome Placa Mãe Hewlett-Packard HP Pavilion g6 Notebook PC Chipset Placa Mãe Intel Cougar Point HM65, Intel Sandy Bridge DIMM3: 4 Gb Samsung M471B5273DH0-CH9 Tipo de BIOS Insyde (06/14/2012) Adaptador gráfico Intel® HD Graphics Family (1841080 KB) Adaptador gráfico Intel® HD Graphics Family (1841080 KB) Acelerador 3D Intel HD Graphics 3000 Monitor LG Philips LP156WH4-TLC1 [15.6" LCD] Adaptador de som IDT 92HD81B1X Intel Cougar Point PCH-High Definition Audio Controller [b-3] Adaptador de som Intel Cougar Point HDMI @ Intel Cougar Point PCH - High Definition Audio Controller [b-3] Controladora IDE Standard AHCI 1.0 Serial ATA Controller Disco rígido SAMSUNG HN-M500MBB ATA Device (500 GB, 5400 RPM, SATA-II) Drive óptico hp DVDRAM GT50N ATA Device Status dos discos SMART OK Teclado Teclado Padrão PS/2 Mouse Synaptics PS/2 Port TouchPad Adaptador de Rede Dispositivo Bluetooth (Rede Pessoal) Adaptador de Rede Realtek PCIe FE Family Controller Adaptador de Rede Realtek RTL8188CE 802.11b/g/n WiFi Adapter (192. [ TRIAL VERSION ]) Controladora USB2 Intel Cougar Point PCH - USB EHCI #1 Controller [b-3] Controladora USB2 Intel Cougar Point PCH - USB EHCI #2 Controller [b-3] Dispositivos USB Generic Bluetooth Adapter Dispositivos USB HP Webcam-101 Dispositivos USB USB Composite Device Dispositivos USB USB Mass Storage Device Bateria Bateria de Método de Controle Compatível com ACPI da Microsoft
rivaldo Posted September 25, 2012 Posted September 25, 2012 Segue aqui o hardware do desktop que consegui instalar o hackintosh um HP 666. Este apenas a wifi não funciona, mas estou procurando uma compatível para substituir ou o kext da Ralink em 64bits. Processador Mobile DualCore Intel Core i3-2330M, 2200 MHz (22 x 100) Nome Placa Mãe Hewlett-Packard HP Pavilion g6 Notebook PC Chipset Placa Mãe Intel Cougar Point HM65, Intel Sandy Bridge DIMM3: 4 Gb Samsung M471B5273DH0-CH9 Tipo de BIOS Insyde (06/14/2012) Adaptador gráfico Intel® HD Graphics Family (1841080 KB) Adaptador gráfico Intel® HD Graphics Family (1841080 KB) Acelerador 3D Intel HD Graphics 3000 Monitor LG Philips LP156WH4-TLC1 [15.6" LCD] Adaptador de som IDT 92HD81B1X Intel Cougar Point PCH-High Definition Audio Controller [b-3] Adaptador de som Intel Cougar Point HDMI @ Intel Cougar Point PCH - High Definition Audio Controller [b-3] Controladora IDE Standard AHCI 1.0 Serial ATA Controller Disco rígido SAMSUNG HN-M500MBB ATA Device (500 GB, 5400 RPM, SATA-II) Drive óptico hp DVDRAM GT50N ATA Device Status dos discos SMART OK Teclado Teclado Padrão PS/2 Mouse Synaptics PS/2 Port TouchPad Adaptador de Rede Dispositivo Bluetooth (Rede Pessoal) Adaptador de Rede Realtek PCIe FE Family Controller Adaptador de Rede Realtek RTL8188CE 802.11b/g/n WiFi Adapter (192. [ TRIAL VERSION ]) Controladora USB2 Intel Cougar Point PCH - USB EHCI #1 Controller [b-3] Controladora USB2 Intel Cougar Point PCH - USB EHCI #2 Controller [b-3] Dispositivos USB Generic Bluetooth Adapter Dispositivos USB HP Webcam-101 Dispositivos USB USB Composite Device Dispositivos USB USB Mass Storage Device Bateria Bateria de Método de Controle Compatível com ACPI da Microsoft
rivaldo Posted September 25, 2012 Posted September 25, 2012 Espero que as informações ajudem Artur, pois gostaria muito de ter o hackintosh em meu notebook HP tb. Esclarecendo que sou bastante leigo e só consegui no desktop pq. o IATKOS fez tudo sozinho. Muito grato a todos que puderem ajudar. Rivaldo Ribeiro
artur-pt Posted September 26, 2012 Posted September 26, 2012 olá tenta fazer o boot -v GraphicsEnabler=No cpus=1 se parar posta foto onde pára bom hack PB Easy Note TM 86 - i5 430 M - H55M - Ram - 6 GB - Alc272 - Radeon HD 5470 512 QE/CI Lenovo G500 - i5 3230m - HM77 - Ram - 8 GB - Conexant audio - HD 4000 My OS X Files
rivaldo Posted September 26, 2012 Posted September 26, 2012 Prezado Artur, Agradeço muito a dica, pois consegui correr a instalação do !0.7 com um instalador chamado Niresh12495-Lion. Tudo instalou normal mas ainda não consigo dar boot pelo HD e tb. só dá boot com os comandos que vc. me sugeriu (-v GraphicsEnabler=no cpus=1). Poderia abusar da sua boa vontade e conhecimentos e pedir instruções de como resolver isso e se possível como fazer a wifi e ethernet funcionarem? Os demais itens vou tentado por aqui e lhe abusando qdo. tiver dificuldades maiores. Se possível me envie um link para os kexts de rede, ou até todos para minha máquina ou similar. Li em algum local que eu preciso instalar o DSDT do MacBook Por 8,3 mas confesso que nem imagino o que seja isso ou como conseguir e instalar. Grato milhões de vezes companheiro. SDS Rivaldo Ribeiro
artur-pt Posted September 27, 2012 Posted September 27, 2012 olá usa isto e posta dev id e vendor id da lan http://www.Olarila.com/forum/viewtopic.php?f=6&t=25 e dá uma leitura nisso http://www.Olarila.com/forum/viewtopic.php?f=2&t=1713 bom hack PB Easy Note TM 86 - i5 430 M - H55M - Ram - 6 GB - Alc272 - Radeon HD 5470 512 QE/CI Lenovo G500 - i5 3230m - HM77 - Ram - 8 GB - Conexant audio - HD 4000 My OS X Files
