GabfPump Posted October 24, 2020 Posted October 24, 2020 Hello everyone, I have a problem with the pendrive assembly, I have already downloaded two images of the .17 and .14 catalina. at the end of the process, an error called "physical" appears, something like that, but the pendrive ends, I configure the bios, and on the boot screen, press f12, select the pendrive and it gives a black screen and goes back to the same menu . Hardware. Intel i3-8100 GTX 1050 TI OC Motherboard: GigaByte H310M hardware print: motherboard cpu:
Administrators MaLd0n Posted October 24, 2020 Administrators Posted October 24, 2020 this nvidia dont work in catalina use this folder https://olarila.com/files/Clover.Folder/EFI CLOVER 100.200.300.400.zip -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Consulting for macOS Hackintosh since 2006 HERE
GabfPump Posted October 24, 2020 Author Posted October 24, 2020 4 minutes ago, MaLd0n said: esta nvidia não funciona na catalina use esta pasta https://olarila.com/files/Clover.Folder/EFI CLOVER 100.200.300.400.zip what do i do with this folder? I'm a beginner, first time I try to install a hackintosh, is there any version that works on the GTX 1050 TI?
Administrators MaLd0n Posted October 24, 2020 Administrators Posted October 24, 2020 paste efi folder in ur efi partition and reboot but forget this nvidia gpu, u need change -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Consulting for macOS Hackintosh since 2006 HERE
GabfPump Posted October 24, 2020 Author Posted October 24, 2020 14 minutes ago, MaLd0n said: paste efi folder in ur efi partition and reboot but forget this nvidia gpu, u need change the high sierra link is offline, could you help me?
Administrators MaLd0n Posted October 24, 2020 Administrators Posted October 24, 2020 is not offline. google drive have a limit -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Consulting for macOS Hackintosh since 2006 HERE
King Posted March 15, 2024 Posted March 15, 2024 (edited) Hello everyone, I have a problem asus h87m-e i7 gtx 1050 ti gigabyte but on reboot after root patching, the verbose shows up and after that, there's just black screen and no display. I tried reset NVRAM but still no display after verbose Hello everyone, I have a problem asus h87m-e i7 gtx 1050 ti gigabyte but on reboot after root patching, the verbose shows up and after that, there's just black screen and no display. I tried reset NVRAM but still no display after verbose mac os monterey config.zip Edited March 15, 2024 by King
Administrators MaLd0n Posted March 16, 2024 Administrators Posted March 16, 2024 Change this gpu to one AMD card with native support -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Consulting for macOS Hackintosh since 2006 HERE
