Im using Lenovo Y450 P7550
And used your run_me to get data.
Could you make some DSDT for that Laptop?
Many Thanks :D
dsdt.driftkingn20.zip
dsdt.diman1.zip
Use forum
[attachment=0]dsdt.diman1.zip[/attachment]
Use forum
Dear MaLD0n
I try this file but this file dont resolve my problem.
I have kernel panic when i boot laptop with removed Ethernet cable:
panic(cpu X caller 0xffffff80002251fb): "TLB invalidation IPI timeout: " "CPU(s) failed to respond to interrupts, unresponsive CPU bitmap:
Dear MaLD0n
post a photo
My Laptop cant't sleep
run on terminal
grep Wake /var/log/kernel.log
post a photo
My screenshot with GraphicsEnabler=Yes and AtiConfig=Hoolock and without Ethernet uplink
http://www.sendspace.com/file/d6c4fm
I made fine screenshot. Before i deleted AppleBluetoothMultitouch.kext and IOBluetoothHIDDriver.kext, IOBluetoothFamily.kext
I think that this is the problem of random kernel panic.
Now, i think, this is the clear picture of kernel panic
http://www.sendspace.com/file/go4w5y
I try to reboot with GraphicsEnabler=No -f -v an d make screenshot
http://www.sendspace.com/file/0v4918
look at the "Kernel Extensions in Backtrace"
Help me Please In page9
8-)
send me your DSDT
This is unresolved problem??? And this is the problem with Ethernet kext???
I dont know, i just ask you.
Thanks for you support
Yes
look at the photo --> "Kernel Extensions in Backtrace"
Hi Mald0n,
can you please make a DSDT for my mobo?
this is my configuration:
-MB: intel dx58so2
-CPU: i7-960
-GC: GTX560
thank you in advance!
send me files
see the first post
what files?
run on terminal
perl -e 'open(CMD, "ioreg -lw0 \| grep DSDT|") or die; while(<CMD>) { chomp; if($_ =~ /\"DSDT\.?\d?\"=<([^>]*)>/) { $buff = $1; open(PIP, "|xxd -r -p > ~/Desktop/dsdt.aml") or die; print PIP "$1"; } }'
DSDT generate in desktop
Yes
MaLD0n
Can you edit my DSDT(audio section), so as not use VoodooHDA(use native AppleHDA). My laptop have HDMI 5650m and internal speaker???
Everest say:
PCI / PnP Audio
Device Description Type
Conexant Cx20585 @ Intel Ibex Peak PCH - High Definition Audio Controller [b-2] PCI
High Definition Audio Controller [1002-AA60] [NoDB] PCI
HD Audio
[ High Definition Audio Controller [1002-AA60] [NoDB] ]
Device Properties:
Device Description High Definition Audio Controller [1002-AA60] [NoDB]
Device Description (Windows) High Definition Audio Controller
Bus Type PCI
Device ID 1002-AA60
Subsystem ID 1179-FD12
Revision 00
Hardware ID PCI\VEN_1002&DEV_AA60&SUBSYS_FD121179&REV_00
[ ATI Radeon HDMI ]
Device Properties:
Device Description ATI Radeon HDMI
Device Description (Windows) Conexant Audio Driver For AMD HDMI Codec
Device Type Audio
Bus Type HDAUDIO
Device ID 1002-AA01
Subsystem ID 00AA-0100
Revision 1002
Hardware ID HDAUDIO\FUNC_01&VEN_1002&DEV_AA01&SUBSYS_00AA0100&REV_1002
[ Intel Ibex Peak PCH - High Definition Audio Controller [b-2] ]
Device Properties:
Device Description Intel Ibex Peak PCH - High Definition Audio Controller [b-2]
Bus Type PCI
Device ID 8086-3B56
Subsystem ID 1179-FF1E
Revision 05
Hardware ID PCI\VEN_8086&DEV_3B56&SUBSYS_FF1E1179&REV_05
[ Conexant Cx20585 ]
Device Properties:
Device Description Conexant Cx20585
Device Description (Windows) Conexant CX20671 SmartAudio HD
Device Type Audio
Bus Type HDAUDIO
Device ID 14F1-5069
Revision 1003
Hardware ID HDAUDIO\FUNC_01&VEN_14F1&DEV_5069&SUBSYS_1179FD12&REV_1003
Second question:
What you recomends to use Hyper Threath and Hyper Boosts of i5???
run on terminal
send me DSDT generate in DESKTOP
Use NativePM + LPC + HPET fix(if you need) + correcty MacModel
Hi.
Can you make a DSDT for me? Here's my spec:
Mobo : ASUS Maximus IV Extreme
Ram : 8 gb DDR3 (4g+2g+1g+1g) running at 1033 (Yes I know it's slow as hell, I WILL upgrade :D )
Gfx : Gigabyte Nvidia GTX 460 1g
Thanks!
