musfiqlitu Posted May 4, 2012 Posted May 4, 2012 my new asus p8h67 m pro mobo ,i7 2600, agp 9500 gt ..... I try to install iatkos s2 v3 with -v cpus=1 busratio=29.... after some time install logo come....but mouse not move ........ plz help..... I intall mac osx 10.5.5/10.5.7/10.6.3 to other pc......and 10.5.7 on this pc....but I failed to install 10.6.3 -10.7.2.... same usb problem. what should I do ? why mouse stop ? ..... plz help
dbm Posted May 23, 2012 Posted May 23, 2012 I got the same problem, and i solved it by typing in boot (F8) -v GraphicsEnabler=No That worked for me. GL HF
artur-pt Posted May 24, 2012 Posted May 24, 2012 hello try to install lion snow leopard don't have support for u cpu, only in 10.6.8 use a legacy boot cd must legacy_kernel to boot and then update to 10.6.8 but my advice for u is to install lion good hack PB Easy Note TM 86 - i5 430 M - H55M - Ram - 6 GB - Alc272 - Radeon HD 5470 512 QE/CI Lenovo G500 - i5 3230m - HM77 - Ram - 8 GB - Conexant audio - HD 4000 My OS X Files
dbm Posted June 8, 2012 Posted June 8, 2012 U need to DISABLE HPT "High Precision Timer" in BIOS > Advanced mode > Advanced > PHC Configuration and after that will work fine.
