Trick - Full Dark Mode on macOS High Sierra
badruzeus
CPU: Intel Core i3-2330M
Motherboard: Asus A43SJ
GPU: Nvidia GeForce GT 520M
Post by badruzeus » 23 Jun 2018, 23:36
Well, the upcoming macOS Mojave comes with DarkMode appearance. Do we need to install 10.14 just to "feel in the dark"? Definitely, No.
So, with these few steps we are able to get it (on my case, I'm running macOS 10.13.5):
1. Open Utilities - Terminal.app
2. Run this command:
defaults write -g NSWindowDarkChocolate -bool TRUE
3. Log out via Apple menu, and then log back in again.
4. For full DarkMode, you may consider to check: Preferences > General > Use dark menu bar and Dock
Now, enjoy Mojave-ish looks a like macOS High Sierra with DarkMode. :)
Feeling not so eye catching with this hack? Just restore the appearance using:
defaults delete -g NSWindowDarkChocolate
Original credit goes to Steve Troughton-Smith: [External Link Removed for Guests]
Laptop: Asus A43SJ (MBP10,1) with Intel Core i3-2330M, nVIDIA GeForce GT 520M 1GB (Fermi GF119)
running macOS Mojave 10.14 (18A314h), OS X El Capitan 10.11.6, Ubuntu 18.04 and Windows 10.
RSR1027
CPU: i3-6006u
Motherboard: 351-351-3LM
GPU: Inter HD 520
Re: Trick - Full Dark Mode on macOS High Sierra
Post by RSR1027 » 23 Jun 2018, 23:53
:lol: :lol: :lol: :lol: :lol: its better its not beta anymore
RSR1027
CPU: i3-6006u
GPU: Inter HD 520
Post by RSR1027 » 24 Jun 2018, 00:03
its working :D :D :D
badruzeus
Post by badruzeus » 24 Jun 2018, 00:09
Not so bad @RSR1027 :D
