3 hours ago, greglamy said:
Hello mald0n,
Here is the generated archive for my hackintosh using your generic opencore efi folder.
Could you please make a fully patched dsdt for me ?
My HW is GB Z390 Aorus Xtreme, RX5700XT. Still using usbinjectall but would like to have a cleaner solution.
Thanks a lot in advance,
Greg
https://filebin.net/841oac1en9t3krst
Thanks a lot.
After having put DSDT in place and in config.plist, I tryed to remove usbinjectall (from kext folder and in config.plist) but then the system refuses to boot.
Two other questions :
- Is there still a specific ssdt for tb3 usable with this config?
- When I try to put my hack on sleep, it immediatly wakes up!
extract new sendme with ioreg
u have thunderbolt card?
