Issues waking HP laptop with keyboard and usb mouse
If I use the keyboard to wake the laptop it sometimes starts sending random keypresses and other times the keyboard stops working. It seems to input what I last typed. I can wake fine if I just use the touchpad.
I cannot wake with an external usb mouse or bluetooth mouse at all like I can on Windows.
Any help will be appreciated. Thanks
Laptop
HP ENVY 17-bw0000
i7-8550U
UHD 620
Send me MacBook-Pro.zip
add a _prw inside xhc device
Quote
Method (_PRW, 0, NotSerialized)  // _PRW: Power Resources for Wake
                Return (Package ()
                    0x6D,
                    0x04
Can you tell me where this is? Do I search the DDST.aml?
Any idea what could be causing the issue with waking from the PS2 keycoard?
Turns out the issue with PS2keyboard is a hardware bug.
Edited by Deihmos
Thanks I got it. Issue with the keyboard is a hardware bug. There is nothing I can do unless someone comes up with a patch. Now I can wake with the mouse it shouldn’t be an issue.
@olarila I found a new bug. If the laptop is running on battery it refuses to sleep if something is connected to the USB ports. It will go to sleep then wake instantly with this patch. Without the patch I have no issues.
Does this only work if the laptop is plugged in? Is there a fix for that?
Thanks.
in many cases _prw cause it
