Can someone help me to fix my configuration?
Can you correct (add / delete / edit configuration & kext) MacOS Catalina running on my laptop (Acer Aspire 5 A514-51KG-36UX)?
Problem:
- iMessage & Facetime can't login, I've tried iMessage Fixer and some tutorials on youtube but it doesn't work (Show message "You cannot sign in to FaceTime on this Mac at this time. To use FaceTime with this Mac, contact Apple Support and provide the code below.)
- Wifi (Qualcomm Atheros QCA9377) can't be used, but I'm using a wifi usb dongle. Maybe there is a way to fix it so that I don't have to use the dongle anymore.
Apart from that, everything went smoothly (audio, ethernet, display etc.)
And I really hope someone can help me in this forum, especially if someone wants to correct EFI, Config & Kext.
And this is the result of the Run Me app on my laptop
https://drive.google.com/file/d/1vuhJzU5hDvQsLFNYgPoCxahKWacXJIyB/view?usp=sharing
is common in hackintosh. need a good serial
On 8/27/2020 at 10:23 PM, Yosa Tristian said:
 I've tried it and it doesn't work. By the way, my Mac App Store is running smoothly since the first, only iMessage & Facetime doesn't work.
You need to place the nullethernet.kext in your kext folder and the .aml file in your ACPI folder. That should fix your issue. Be sure to add the entries to your open core config.plist
You will know it is working by seeing a generic ethernet connection in your network settings. Then just sign in to all as usual.
Very true.
Edited by MrHomebrew
