muzyzakey Posted August 19, 2020 Posted August 19, 2020 Hi. HP EliteBook 8460p Intel Core - i7 2720QM 4GB RAM Intel HD3000 I managed to install High Sierra from the olarila image i downloaded and used OpenCore 0.6.0 Guide and made the config.plist as everything described in that guide. I have several problems, 1. My trackpad works but the cursor isnt stable / i cant click or do anything 2. Battery Percentage not Displayed. 3. Sound is not working Im very much new to this, your support and guidance will be much appreciated.. i have attached my OC Folder' EliteBook8460.rar
muzyzakey Posted August 23, 2020 Author Posted August 23, 2020 Hi, My TrackPad Doesnt Work, I Tried the Following Solutions 1. ApplePS2Smarttouchpar.kext 4.6.5 Verison Trackpad works, Multi touch Works, But the cursor is very very very slow, and the trackpad settings is empty in system preferences. 2. Rehabman Version of VoodooPS2controller.kext Multi touch doesnt work, cursor movement is ok, but trackpad doesnt work (shows to tell to connect bluetooth device) 3. VoodooI2C + VoodooSynaptics dint Work at all. Please anyone suggest help me complete my build, I can contribute by writing a complete guide if this works well
Daniyal Shehzada yasin Posted July 22, 2022 Posted July 22, 2022 Try Synaptics Trackpad Driver i have the same laptop and i searched for my trackpad model and this came up so download Synaptics Trackpad driver and install it into clover if you have another hackintosh
