Install MacOS Catalina / Big Sur / Monterey on Mobos Serie 300 / 400 / 500 / 600 with Intel 8th / 9th / 10th / 11th / 12th Gen Desktop Processors using OpenCore or Clover bootloader
Donation with Binance 0xdbe48ef6b158f1dd0035d7f49555c99e52f72714
Donation with Stripe https://tinyurl.com/2ssnydn6
Donation with BuyMeaCoffee https://tinyurl.com/bvsbpf6e
Donation with BTC 33HeGCuCSh4tUBqdYkQqKpSDa1E7WeAJQ3
Donation with PicPay @danielnmaldonado
Donation with Mercado Livre https://tinyurl.com/y9evkj5u
CPUID for Rocket Lake Processors
{Cpuid1Data} EB060900 00000000 00000000 00000000
{Cpuid1Mask} EB060900 00000000 00000000 00000000
CPUID for Alder Lake Processors
{Cpuid1Data} 55060A00 00000000 00000000 00000000
{Cpuid1Mask} FFFFFFFF 00000000 00000000 00000000
1 -Create a USB bootable
Use this tool and download Catalina or Big Sur from Apple servers
Catalina
installScript_allfullapp.zip
Big Sur / Monterey
installScript_1016fullapp.zip
Credits: crazybirdy
Copy Catalina / Big Sur installer to Applications folder, open terminal and run
Monterey:
sudo /Applications/Install\ macOS\ Monterey.app/Contents/Resources/createinstallmedia --volume /Volumes/MyVolume
Big Sur:
sudo /Applications/Install\ macOS\ Big\ Sur.app/Contents/Resources/createinstallmedia --volume /Volumes/MyVolume
Catalina
sudo /Applications/Install\ macOS\ Catalina.app/Contents/Resources/createinstallmedia --volume /Volumes/MyVolume
Mojave:
sudo /Applications/Install\ macOS\ Mojave.app/Contents/Resources/createinstallmedia --volume /Volumes/MyVolume
High Sierra:
sudo /Applications/Install\ macOS\ High\ Sierra.app/Contents/Resources/createinstallmedia --volume /Volumes/MyVolume
If you want check one step by step, check here
-Opencore Vanilla Tutorial
https://tinyurl.com/ycvcnp8h
2- EFI folder USB installation
-EFI OpenCore Folder
Paste EFI folder in EFI partition in your USB STICK
https://tinyurl.com/ybr968w3
-EFI Clover Folder
3- EFI folder SSD
Paste EFI folder in EFI partition SSD
-EFI Clover Folder
4- Start Fine Tune
Run this app and post full dump here for full ACPI solution
RunMe.app
https://tinyurl.com/y9562hz7
If you like a SSDT way, here we go (SSDT is a incomplete way)
SSDT-OLARILA.aml.zip
5- USB Solution
USB Solution.zip
Use these kexts and follow this tutorial for remap USB ports
--DSDT PATCHES--
-FIX ERRORS AND WARNINGS
-FIX ACPI ERRORS
-REMOVE UNUSED SCOPES / DEVICES
-HIGH PRECISION EVENT TIMER
-SATA SERIE ID
-DMAC
-REMOVE LINES, PROBLEMATIC and UNUSED
-FIX K.P in REBOOT
-NVRAM
-REAL TIME CLOCK
-SLPB
-DARWIN / WINDOWS
-XHCI
-PLUGIN TYPE
-HDEF
-ARTC
-IPIC
-TIMR
-SBUS
-BUS1
-MCHC
-ALS0
-SHUTDOWN
-UAR1
-LAN
-FWHD
-USBX
-PMCR
-PPMC
-XSPI
-kUSBCompanionIndex
-io-device-location
-IMEI
-EC
-PNLF
-ARPT
-GFX0
-NVME
-ACPI-WAKE-GPE
-DTGP
-HDMI / HDAU
--SCREENSHOTS--
-If you want to buy me a beer - Donations with PayPal
https://tinyurl.com/r2bvzm7
Big Thanks to XLR and your Badass Motherboard, Ultrafast CPU, Coolest Heatsink, Huge Graphics Card, Tonnes of RAM,
Gigantic Hard Drive, Lightspeed Disk Burner, Professional Sound Card, Massive LCD Display.
-Credits and thanks to the old and new people in the community who developed patches, kexts and bootloaders!
Slice, Kabyl, usr-sse2, jadran, Blackosx, dmazar, STLVNUB, pcj, apianti, JrCs, pene, FrodoKenny, skoczy, ycr.ru, Oscar09, xsmile, SoThOr, RehabMan, Download-Fritz, Zenit432, cecekpawon, Intel, Apple, Oracle, Chameleon Team, crazybirdy, Mieze, Mirone, Oldnapalm, netkas, Elconiglio, artut-pt, ErmaC, Pavo, Toleda, Master Chief and family, bcc9, The King, PMheart, Sherlocks, Micky1979, vit9696, vandroiy2013, Voodoo Team, Pike R. Alpha, lvs1974, Austere.J, CVad, headkaze, onemanosx, erroruser, Jenny David, Sampath007, Facebook Hackintosh community, Facebook Olarila community, SchmockLord, daliansky and many, many, many others!
3 hours ago, Idea Visuals Tech said:
fail on the second part of installation. never finish.
post one photo
6 hours ago, ahadrox said:
In the screenshot, I see Apple Inc. Mac-FCxx instead of Acidanthera Mac-FCxx, why yours is Apple Inc. and mine is Acidanthera ?
remove "SpoofVendor" in ur smbios
Hey Maldon, I need a api solution, please see attached my runme. I whatsapp'd you as well with the runme file.    if possible to do an acpi solution for clover AND open core would be great!  also would you be able to get my intel uhd 630 graphics working properly?  would be great
intel i3-10100, asrock h470m-itx/ac, WD nvme ssd, 16gb ram corsair vengeance ddr4
can't seem to attach runme file here, will also post in private message.
hey. my cel is broke 2 hours ago lol
buy new tomorrow =]
post here
22 hours ago, kiimon said:
Hello
Successfully Installed Catalina 10.15.7 I use two screens 144hz (DP) and 60hz (HDMI) both of them work, on restart getting kernel panic message, rune me app creates to big file and can't post it on here unfortunately.
created separate partition for Big Sur and used same EFI folder form Catalina (-EFI OpenCore Folder Desktop 10th Intel Processors) but getting black screen straight after install is finished.
  • Asus TUF Gaming Z490 plus
  • Intel i7 10700k
  • Samsung m.2 970 evo plus 500GB
  • sapphire rx 5700 xt nitro+
  • 16gb corsair vengeance
up in google drive or other service
53 minutes ago, Spaikys said:
Here is link to google drive
4 hours ago, Spaikys said:
Thank you, now I'm able use my Big Sure 11.0.1 to thanks to your DSDT. Still there seems to be a problem in Big Sur and Catalina with my ram please se pic.
use iMacPro1,1 smbios with shikigva=128
Sorry for stupid question but where do I put that shikigva=128 ?
Edited by Spaikys
nvram tab opencore
boot tab clover
Hello Can you please provide me DSDT for this configuration??
https://www.dropbox.com/s/r356ib3e3u5trt0/Send%20me%20iMac-Pro.zip?dl=0
Config : Intel Core i5 10400
Mother board : Asus H410M Prime
Ram : Corsair 8 GB
  • Thanks 1
Hello,
Thanks a lot for dsdt. but do have an idea why my android studio not opening it crashes every time I start says reserved VM address space (unallocated). I already enabled Virtualization tech in bios.
i edited ur files
On 11/6/2020 at 7:35 PM, MaLd0n said:
nvram tab opencore
boot tab clover
Sorry for late reply, I'm on OC so I head to NVRAM tab and add as boot argument that shikigva=128?
thanks again.
Yes
