Hello Friends,
i am looking for Hackintosh Clover EFI folder for catalina 10.15.6  ice lake processor and my laptop is HP Spectre x360 13 Convertible
specs are
Intel® Core™ i7-1065G7 (1.3 GHz, up to 3.9 GHz, 8 MB cache, 4 cores)+ Intel® Iris® Plus Graphics+16 GB Memory (onboard)(OLED)
13.3" diagonal 4K UWVA BrightView micro-edge AMOLED multitouch (3840 x 2160)
1 TB Intel® SSD + 32 GB Intel® Optane™ memory
Intel® Wi-Fi 6 AX 201 (2x2) and Bluetooth® 5 Combo
Edited by ganesh8592
ice lake video is  mistery
trackpad is added in i2c
1 hour ago, Rizqiii XD said:
can i install catalina on intel core i3  1005g1 ?? - lenovo v14 iil
yes
https://tinyurl.com/y25ju7xp
Lenovo S340 with i7-1065G7? I can boot and I have installed but I get no backlight 90% of the time.
Just getting into OC after being a Clover guy for ever.
Edited by Pho3n1x73
5 to %
WhateverGreen.kext.zip
11 hours ago, Rizqiii XD said:
i cannot format my disk to apfs on disk utility catalina (error)
format entire disk
Hi,
I have a thinkbook 14 iil with a I7 1065G7 integrated Iris Intel Graphics, and still stuck on [EB|#LOG:EXITBS:START] I tried solution proposed here  https://dortania.github.io/OpenCore-Install-Guide/troubleshooting/extended/kernel-issues.html#stuck-on-eb-log-exitbs-start
also cfg unlocked my bios changed my dvmt, applied some hot patches for renaming but nothing changed still stuck at the same position, when tried the debug version of open core it seems the boot loader is unable to load or to locate the prelinked kernel files, is there any suggestion about what can I do to solve this issue.
https://opencore.slowgeek.com/?file=laptopicelake063ocluOD&rs=laptopicelake063
also when starting Windows using open core all devices are working fine!
Thanks!
Edited by Mouad Cherkaoui
On 12/10/2020 at 11:06 PM, Mouad Cherkaoui said:
Hi,
Thanks!
same problem here
