VoodooHDA - problem with speedstep after waking
Hello
Sorry for my English (google translator)
He asked for help for vodooHDA i speedstep after sleep
I voodooHDA 2.7.3 running sound and microphone.
CPU clock speed changes. speedstep is OK
after waking no speedstep, the processor is working full
Without voodooHDA after waking speedstep works well is ok
Generally the biggest problem is with the power mangament (speedstep) after waking up when the system is voodoohda
Please help in solving a problem with sound and speedstep after waking.
DSDT is from MaLd0n
My Info.plist ...
<plist version="1.0">
<dict>
<key>BuildMachineOSBuild</key>
<string>11A511</string>
<key>CFBundleDevelopmentRegion</key>
<string>English</string>
<key>CFBundleExecutable</key>
<string>VoodooHDA</string>
<key>CFBundleIdentifier</key>
<key>CFBundleInfoDictionaryVersion</key>
<string>6.0</string>
<key>CFBundleName</key>
<key>CFBundlePackageType</key>
<string>KEXT</string>
<key>CFBundleShortVersionString</key>
<string>2.7.3</string>
<key>CFBundleSignature</key>
<string>????</string>
<key>CFBundleVersion</key>
<key>DTCompiler</key>
<string>4.2</string>
<key>DTPlatformBuild</key>
<string>4B110</string>
<key>DTPlatformVersion</key>
<string>GM</string>
<key>DTSDKBuild</key>
<string>10J567</string>
<key>DTSDKName</key>
<string>macosx10.6</string>
<key>DTXcode</key>
<string>0410</string>
<key>DTXcodeBuild</key>
<key>IOKitPersonalities</key>
<dict>
	<key>VoodooHDA</key>
	<dict>
		<key>IOClass</key>
		<key>IOMatchCategory</key>
		<key>IOPCIPrimaryMatch</key>
		<string>0x3b568086</string>
		<key>IOProviderClass</key>
		<string>IOPCIDevice</string>
		<key>IOUserClientClass</key>
		<key>InhibitCache</key>
		<true/>
		<key>MixerValues</key>
		<dict>
			<key>Mic</key>
               		<string>90</string>
               		<key>Monitor</key>
               		<string>0</string>
               		<key>PCM</key>
               		<string>99</string>
			<key>IMix</key>
               		<string>99</string>
			<key>Line</key>
               		<string>99</string>
               		<key>Rec</key>
               		<string>99</string>
               		<key>Speaker</key>
               		<string>99</string>
               		<key>iGain</key>
               		<string>0</string>
               		<key>IMix</key>
               		<string>99</string>
		</dict>
		<key>NodesToPatch</key>
           		<array/>
               	<key>Noise</key>
		<integer>2</integer>
		<key>Vectorize</key>
		<true/>
		<key>VoodooHDAEnableHalfMicVolumeFix</key>
		<false/>
		<key>VoodooHDAEnableHalfVolumeFix</key>
		<false/>
		<key>VoodooHDAEnableMuteFix</key>
		<false/>
		<key>VoodooHDAEnableVolumeChangeFix</key>
		<false/>
		<integer>0</integer>
	</dict>
</dict>
<key>OSBundleLibraries</key>
<dict>
	<key>com.apple.iokit.IOAudioFamily</key>
	<string>1.1fc9</string>
	<key>com.apple.iokit.IOPCIFamily</key>
	<string>2.1</string>
	<key>com.apple.kpi.iokit</key>
	<string>9.0.0</string>
	<key>com.apple.kpi.libkern</key>
	<key>com.apple.kpi.mach</key>
	<key>com.apple.kpi.unsupported</key>
</dict>
</dict>
</plist>
ASUS G51JX-X5 10.7.3 Lion Intel Core i7 720QM 6GB 500GB 15.6IN FHD GeForce GTS360M
HM55, Intel 5 Series Chipset, ALC663, AR8131, AR9285,
If I understand correctly, the problem only happens when using VoodooHDA, right?
I guess you should report that to VoodooHDA developers, or use other audio kext.
Have you tried previous versions of VoodooHDA?
Yes
Other versions do not work or KP :(
