Donation with Binance 0xdbe48ef6b158f1dd0035d7f49555c99e52f72714
Donation with Stripe https://tinyurl.com/2ssnydn6
Donation with BuyMeaCoffee https://tinyurl.com/bvsbpf6e
Donation with BTC 33HeGCuCSh4tUBqdYkQqKpSDa1E7WeAJQ3
Donation with PicPay @danielnmaldonado
Donation with Mercado Livre https://tinyurl.com/y9evkj5u
USB Remap after BigSur 11.3 check link bellow
https://www.olarila.com/topic/14220-video-guide-usb-port-mapping-guide-2021-bigsur-113-with-no-xhci-port-limit/
-Downloads-
-USB Inject All by RehabMan
USBInjectAll.zip
-Hackintool by HeadKaze
https://tinyurl.com/ymfp8fmw
-IORegistry Explorer by Apple
IORegistryExplorer.app.zip
-Usb Connectors in ACPI Specification / Pages 524 and 525-
https://tinyurl.com/4wtntkfm
-USB Patches Clover-
https://tinyurl.com/y25r5e5m
-Some observations before start-
-We need one USB 2 stick, one USB 3 stick and one USB-C stick
-Old mobos with EHCI devices, need rename EHC1/EUSB to EH01 and EHC2/ USBE to EH02
-USB ports with devices permanently attached (eg. M.2 Bluetooth card) should be set to “Internal”
 -HSxx ports connected to USB3 ports should be set to USB3 (Skylake+)
-Internal HUBs are typically connected to ports PR11 and PR21 and therefore should be set to “Internal”
-USB-C
  • TypeC:
    • If it uses the same HSxx/SSxx in both orientations, then it has an internal switch (use “TypeC+Sw”)
    • If it uses a different HSxx/SSxx in each orientation, then it has no switch (use “TypeC”)
-Tutorial-
  • Thanks 3
Good bro you are genius ?
HackBook Pro :-HP DV6-6121 TX (Win 10 Pro + macOS 10.13.6 + OC )
Hac Pro:-GA-B365-D3H, Core i5 9440F AMD RX 580 8 GB (Win 10 Pro + macOS 10.15.7 + Big Sur Beta )
Hac Pro:-z97 sabertooth mark 2, Core i7- i7 4790k with GT 740 2GB and 32 GB Ram (OC+Catalina)
iHack:- Assus M2N68-AM-SE2,AMD Athlon+LE-1640,250 SSD ,4GB DD3 800MHZ Nvidia 9400GT (win 10 and 10.9.5+10.10.5)
iHack:-GA875M-D3H ,core-i5 3250,NVDIA 610-2GB 27"LED,8GB DDR3 1600mhz, (Only 10.10.5+10.11.6 with CLOVER)
iHack:-GA-78LMT-S2PT ,AMD Phenom II-X2 560,Radeon 6770 1 GB ,onboard Radeon HD 3000 not tested 4 GB DDR-3 1333 MHZ (10.11.6+Win 10 pro) Special thanks....  To Genius donovan6000 For Mode Bios (WiFi +BT Whitelist removed) & Amazing Hackintosh Guides and tutorial and much more visit this blog Hackintosh Mumbai
Just enjoy!
22 minutes ago, HamadaElhag said:
How can apply this on clover
same procedure
Hello Maldon
I'm trying to set the usb on Asus Z97-Pro wifi ac motherboard
as boot I use Clover added patches usb 10.15 and USBInjectAll.kext
Question: in the first photo I connected usb 2 and usb 3 of the case I have to set them as internal
Question: in the second photo as you see usb 2 and usb 3 I have to set them as internal or not
Bluetooth I have to set it as internal
If you can help me thanks
Edited by iFabio
Internal is bluetooth, cam, cooler usb cable.
in ur case u need kil devices EHC1 and EHC2, all work inside xhc device in ur case, just remap
1 hour ago, iFabio said:
if I understand correctly the usb I have to set them all as internal
only bluetooth, cam, cooler usb cable need set to internal
what do you mean by cam, cooler usb cable
just check hackintool
ur usb port with cam set to internal, read observations in first post
Hello Maldon
procedure: applied the two Clover patches in config.plist and added USBInjectAll.kext restarted
launched Hackintool usb app cleared everything and reloaded
I plugged USB 2 into all USB 2 ports on the motherboard and USB 3 into all USB 3 ports on the motherboard
now i should set the usb using hackintool app you can help me configure them
see photo:
XHC HS11 USB 2 case
XHC HS12 USB 2 case
XHC SS01 USB 3 case
XHC SS02 USB 3 case
2 minutes ago, iFabio said:
Hello Maldon
first thing
u dont need eh01 and eh02, need kill it and start remap only xhc
12 minutes ago, MaLd0n said:
first thing
can you tell me how to do it
i forgot how kext i just have to use USBInjectAll.kext i also have XHCI-unsupported.kext
Edited by iFabio
Hello Maldon
replaced config.plist and DSDT.aml
I connected USB 2 to all USB 2 ports on motherboard and case and USB 3 to all USB 3 ports on motherboard and case
see photo:
XHC HS07 USB 2 case
XHC HS12 USB 2 case
XHC SS01 USB 3 case
XHC SS02 USB 3 case
XHC HS13 bluetooth BCM20702A0
XHC HS11 USB 2  internal motherboard USB 2 connector connected Corsair liquid cooling
