u need connect usb 2 and 3 devices in all usb ports
exclude unnused ports and generate usbports.kext
I don't have to do any usb settings using the hackintool app
HS13 to internal
6 hours ago, MaLd0n said:
HS13 to internal
I leave the others set as usb 3 even if they are usb 2
in ur case all is usb3
usb is used in EHCI devices
5 hours ago, iFabio said:
I pass you IoReg you can check if everything is ok
yes. looks good.
On 8/23/2020 at 1:14 PM, iFabio said:
Hello Maldon
I can improve something
for everything else thank you
looks good
@MaLd0n
Just wanted to take the time to send a thanks for this writeup. Saved me a lot of trouble.
Thanks also for ALL the hard work you've done here. MUCH appreciated. ?
Edited by AppleBytes
mispelled
ThinkPad E531, L530, Inspiron 9400: Core 2 duo @2.16GHz , 4GB, G70 Geforce 7800 (10.7/Lion)
E531: i5-3230M, L530: i3-3110M, Optiplex 780: Core i5 @3.1GHz, 8GB, Geforce 8400 GS (10.9/Mavericks)
HD4000, A68HM-E33 V2 (MS-7721): Athlon X4 860K, 8GB, GeForce GT 730 (10.9/Mavericks)
Just enjoy, bro!
OK I've been working on 2 ThinkPads -- 3 actually; 2 E531's and an L530. While applying this method on the L530 to make the USB ports accept USB sticks. I discovered that the battery icon up in the notification tray disappeared after reboot. But all the USB ports worked correctly. I think the battery is also controlled on/by the USB bus. Can anyone provide some more insight?
Thanks for all your time, and consideration.
--Chris
these models need a battery patch no?
After mapping the ports, my USB3 ports can't recognize USB2 devices, how can I fix it?
And for some reason I can't see the USBPorts.kext loading in kextstat, is it normal?
(Z490-UD / Clover/ Catalina)
Edited by XLR
hsxx ports is there?
if dont work, stay with usb injectall and use ssdt-uiac instead usbports.kext
Hello I have a thinkpad E531 model and I would like to learn how to solve the problem of the battery notification because the icon does not appear at the top, right now I have an olarilla with the mojave version, thank you very much.
I did not find any presentation thread in the forum, sorry, I just wanted to congratulate you for this great community, it is really great, my English is not too good, sorry, greetings.
Edited by demool
Thinkpad E531 10.14.6  ver. olarilla.  Motherboard chinese. Dual XEON E2560. 16GB. RX580 ver. Catalina 10.15.7 Thinkpad x200s . LION 10.7.3 ver.niresh Thinkpad. M72e Tiny  recently purchased, in the hackintosh installation phase.
