kingofkings6 Posted March 31, 2012 Posted March 31, 2012 i modified my dsdt error free but i'm having problem with sleep when i put lion on sleep it wake up in 1 seconds and this cycle go on.... what i suppose to do dsdt.aml 2.zip
Cassio Posted March 31, 2012 Posted March 31, 2012 Read http://Olarila.com/forum/viewtopic.php?f=19&t=634 If the system goes to sleep and wakes immediately, look for "Wake reason" in kernel log and edit method _PSW or remove _PRW from that device in DSDT. -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Consulting for macOS Hackintosh since 2006 HERE
kingofkings6 Posted March 31, 2012 Author Posted March 31, 2012 Read http://Olarila.com/forum/viewtopic.php?f=19&t=634 yep i saw it before, how do i see in kernel log how do i edit method _PSW, i mean what edit i should make i remove _PRW and nothing changed... i'm new in this, plzzz tell me brief
Cassio Posted March 31, 2012 Posted March 31, 2012 Which device is causing wake? Before removing _PRW try applying USB patches (EHCI, UHCI) for your chipset. _PSW edit is to make it always store zero, remove the condition on arg0 http://Olarila.com/forum/viewtopic.php?f=19&t=301#p2860 -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Consulting for macOS Hackintosh since 2006 HERE
kingofkings6 Posted March 31, 2012 Author Posted March 31, 2012 Which device is causing wake? Before removing _PRW try applying USB patches (EHCI, UHCI) for your chipset. _PSW edit is to make it always store zero, remove the condition on arg0 http://Olarila.com/forum/viewtopic.php?f=19&t=301#p2860 AFTER lookin at link you post what saw in terminal that >>> Wake reason = EHC2 EHC1 & Wake reason = EHC2 what does it mean??
Cassio Posted March 31, 2012 Posted March 31, 2012 It means EHC1 and EHC2 are causing wake. Apply EHCI patch for your chipset before doing _PRW or _PSW edits. -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Consulting for macOS Hackintosh since 2006 HERE
neon_cracker Posted August 31, 2012 Posted August 31, 2012 Could you please reply with a solution for further documentation for others who are experiencing this problem, like me!
pmdsp Posted August 31, 2012 Posted August 31, 2012 He may or may not come back to this thread. Its better you ask for help. Attache your DSDT and write about the issue you have. ASRock H67M ITX HT, i5 2500K 8GB Ram GB Score - 9815
limp Posted October 22, 2012 Posted October 22, 2012 Hi, i also have sleep problems, or better, "wake" problems. After changing _PSM Method for EHC1 the machine goes to sleep well and stays there (first problem solved, does not wake up within 1sec anymore). But now the machine does not wake up anymore. if the power button is pushed, the activity led flashes but nothing happens. no fan, no hdd noise, nothing. holding power button to send machine hard off does not work, only removing battery will have any effect. Have tried all fixes via DTSE, at the moment do not know where to search the problem, i have attached my dsdt, hopefully someone will have a clue to give me a hint, Best Regards, limp DSDT.aml.zip
