Donation with Stripe https://tinyurl.com/2ssnydn6
Donation with BuyMeaCoffee https://tinyurl.com/bvsbpf6e
Donation with BTC 33HeGCuCSh4tUBqdYkQqKpSDa1E7WeAJQ3
Donation with PicPay @danielnmaldonado
Donation with Mercado Livre https://tinyurl.com/y9evkj5u
-Downloads and Useful links-
SSDT Ola for all chipsets - SSDT-OLA.aml.zip Use in USB Stick Installation
ESP Mounter Prohttps://tinyurl.com/y7q4z4lg
OpenCore Configuratorhttps://tinyurl.com/ybdqc4cz
Clover app with good plist editorhttps://tinyurl.com/ydbyczzn
Catalina Vanilla 10.15.6https://tinyurl.com/y2rwtnla
USB Port Mapping with Hackintool - https://tinyurl.com/y4mqfahz
You can download OpenCore release in GitHub page. Check link bellow.
OpenCore Releaseshttps://tinyurl.com/yy3yhn7s
If you like a SSDT way, here we go
SSDT Skylake and Kabylake
SSDT-OLARILA.SKL and KBL.zip
SSDT Coffeelake+
SSDT-OLARILA.CFL+.zip
-About OpenCore Configurator-
Go to Preferences/OpenCore Settings, select correct OpenCore Version and avoid some mysteries
-Tutorial-
Compiling OpenCore - https://youtu.be/n69xHovy0XE?t=2
Creating EFI folder - https://youtu.be/n69xHovy0XE?t=545
OpenCore Sanity Checker - https://youtu.be/n69xHovy0XE?t=610
Acpi for easy boot - https://youtu.be/n69xHovy0XE?t=837
Generating SMBIOS - https://youtu.be/n69xHovy0XE?t=901
Checking Kexts - https://youtu.be/n69xHovy0XE?t=941
Checking Drivers - https://youtu.be/n69xHovy0XE?t=1037
Audio Solution - https://youtu.be/n69xHovy0XE?t=1097
Mobile Video Solution - https://youtu.be/n69xHovy0XE?t=1206
USB Solution - https://youtu.be/s7PNgpg9ojg?t=1
Copying EFI folder to EFI partition - https://youtu.be/n69xHovy0XE?t=1291
Full Acpi Solution - https://youtu.be/n69xHovy0XE?t=1331
AMD Vanilla - https://youtu.be/n69xHovy0XE?t=1505
Slice, Kabyl, usr-sse2, jadran, Blackosx, dmazar, STLVNUB, pcj, apianti, JrCs, pene, FrodoKenny, skoczy, ycr.ru, Oscar09, xsmile, SoThOr, RehabMan, Download-Fritz, Zenit432, cecekpawon, Intel, Apple, Oracle, Chameleon Team, crazybirdy, Mieze, Mirone, Oldnapalm, netkas, Elconiglio, artut-pt, ErmaC, Pavo, Toleda, Master Chief and family, bcc9, The King, PMheart, Sherlocks, Micky1979, vit9696, vandroiy2013, Voodoo Team, Pike R. Alpha, lvs1974, Austere.J, CVad, headkaze, onemanosx, erroruser, Jenny David, Sampath007, Pavo, mackie100, Facebook Hackintosh community, Facebook Olarila community and many, many, many others!
  • Like 2
  • Thanks 1
4 hours ago, victorxtitan said:
Open Xcode for first time, restart the app and try again
thank you for suggestion still no luck, but after digging from internet, command line below fix the problem
sudo xcode-select -s /Applications/Xcode.app/Contents/Developer
Dell |Inspiron 15 500 | i5-1035G1 | Intel(R) UHD Graphics
use realease xD
https://github.com/acidanthera/OpenCorePkg/releases
  • Thanks 2
12 minutes ago, Raktim Dey said:
My USB3.0 doesn't work..all is HS0* something. I don't know what to do. I'm using USBINJECTALL.
what hardware?
31 minutes ago, Raktim Dey said:
Corei3 7100 with Gigabyte B250m-hd3 motherboard , 16gb ram, MACOS Catalina, rx580 8gb.
https://www.olarila.com/topic/9390-video-guide-usb-port-mapping-with-hackintool/
1 hour ago, ahadrox said:
Does it says it has no EFI partition in it? It's just the dmg only?
yes. dmg renamed to raw
just rename .raw to .dmg, mount efi partition and paste ur efi folder ;)
  • Thanks 1
Thank you very much. I appreciate your work.
Enjoy!
  • Thanks 1
Is there way to boot OC BIGSUR from UBUNTU GRUB bootloader? My OC EFI do not support to boot UBUNTU and WINDOWS too. Help me Linux users...?
Edited by MsujE
bootkey dont work?
