hi @MaLd0nthis is my dsdt which you help me once to compile on line 3179
Method (_REG, 2, NotSerialized)  // _REG: Region Availability
when I use this ssd-igpu.aml I get this
api error method parse/execution failed[\_sb.pci0.lpcb.h_ec._reg] ae_not_found when it is there as day please help
DSDT.aml SSDT-IGPU.aml
Untitled.zip
Edited by Moshe Lyahovsky
stuck a kp message
for gpu use bootloader to inject properties
inject igpu properties via bootloader
my problem is this
DefinitionBlock ("", "SSDT", 2, "hack", "IGPU", 0x00000000)
    External (_SB_.PCI0.IGPU, DeviceObj)    // (from opcode)
    Scope (_SB.PCI0.IGPU)
no matter how Manny times I change _SB_ to _SB it still keeps on saving it the way it wants to and failing to load you have the file in the original post can you shed some light on this history and maybe modify that file
