Hey people, hope you are having a great day!
I installed big sur and everything went smoothly during the installation process but after i booted up macos didn't detect any ethernet ports.
Motherboard: Gigabyte B360m H rev 1
CPU: I5 8400
RAM: 16gb kingston @ 1666mhz i think
If you have any ideas i would be grateful.
4 hours ago, gruthamodder said:
Thanks for the reply! I tried your solution but for some reason it still only detects nothing.
use previous version
I know i might be annoying you since i don't know a lot about hackintosh builds but when i tried to go back to catalina 15.3 the installer always failed.
It would install the first part and when it needs to reboot it just gets a cpu error(panic) after "restarting with exit code 0x0".
The funny thing is that it always worked before. Also i noticed that now i cannot change the boot arguments. I cannot delete arguments, it does not save them after i go back from the arguments page in boot.
When i edit the config.plist it does not change a thing...
Could it be that you guys updated the installer package? (".raw file")
Before it only had 3 arguments but now it has like 5 or 6 and i think that it is causing the issue.
i have same spects b360 m d3h , i5 8400 , 32 gb ram .. please help me out .. during installation of catalina a different language is popped up in installation menu , and during the installation of big sur , it didnt boot up  ...
if possible then please provide the   EFI  folder .. please
it will be much helpfull
On 8/4/2020 at 8:31 PM, MaLd0n said:
@MaLd0n i installed your olarila big sur on desktop coffe lake but fl studio is freckling and glitching in screen  and also i have a problem about internet on coffee lake desktop graphic card intel UHD Graphics 630 7MB
i have another computer lenovo with motherboard lenovo lnvnb 16 12 16 cpu is tigerlake computer laptop is V14 G2-ITL Laptop (Lenovo) - Type 82KA
it says when booting on efi the verbos words says Apple Ps2 controller like photo ive seen on a wbsite its the same as my computer  this is not my original photo i found it on github but i have the samme problem please help me
STUCK AT 'APPLEPS2CONTROLLER...' · Issue #24 · tunglamvghy ... STUCK AT 'APPLEPS2CONTROLLER...' · Issue #24 · tunglamvghy ...
i don't understand why install big sur on a coffee lake install directly sequoia, Big sur is too old now and does not have updates anymore...
Edited by moishiteru
Asus Vivobook X512DA Ventura 13.7.8 (Works like a charm)
Lenovo ideapad Z710|Sequoia 15.7.8
Desktop: Asus Z97-C|CPU intel i7 4770K|Nvidia GT 720 2GB|Sequoia 15.7.8| OC 1.0.7
Mac Mini Mid 2010|Sequioa 15.7.8
Nucintosh NUC5i3ryk|Sequoia 15.7.8
Iphone 14 128GB ios 26.5
like the problem is that it show me the image i showed you before it says "Apple ps2 controller"
Apple ps2 keyboard" help me fix this come on guys .
On 8/11/2025 at 8:02 PM, MaLd0n said:
can you help me to do it please?
post your efi folder
