Hi,
I successfully installed High Sierra from your raw image.  My problem is when I rebbot from install image, using the usb to do the post install I get lots of screen filickering and impossible to continue with post install.  Any help would be appreciated.  FYI, config 1 does not work.  I used config2 for installation and post install.
My laptop is a second generation i7.  It comes with nvidia GTX 440M graphics card.
Any help is really appreciated, thanks.
Bid
use nv_disable=1 for boot into system
first step...boot from hdd/ssd
