Hi, both apps crashing on startup; I am using OpenCore v0.6.0. IGPU is enabled in BIOS but primary GPU is PEG. VideoProc shows hardware info OK. But I don't get it why tis crash happening. All kexts and drivers are latest version. Any idea how can I fix this problem?
Edited by telepati
Case closed. I finally found the solution. I used  ig-platform-id= 0x07009b3e before and when I changed ig-platform-id down below everything works now. PEG is primary, IGPU also enabled on BIOS with this ig-platform-id.
Edited by telepati
