13 hours ago, MaLd0n said:
dsdt é o mesmo
A DSDT que eu tenho roda no Clover estava no mojave. Ela serve para o Opencore?
No clover ela sobe mas no opencore nao vai da erro no acpi
Edited by gugadj
17 hours ago, brumas said:
maybe you need to make some settings in the config to make the disk visible?
set Scan Policy to 0 in Misc/Security
17 hours ago, HUYNH ANH said:
My Laptop ( dell 3567 i5-7200U , intel HD620) error
lapic or video problem, no?
16 hours ago, MorenoAv said:
no VideoProc HEVC está desativado, como resolvo isto?
https://www.olarila.com/topic/5295-guide-hardware-encoder-hardware-decoder-video-processing-hevc-support-intel-quick-sync/
13 hours ago, Frankovich said:
Dear @MaLd0n
try with clover and full dsdt patched
13 hours ago, hwp_2804 said:
hi @MaLd0n here's the file, hopefully this time is rights :)  Send me admin.zip
Aquele que eu editei dois dias atrás é pra oc
13 hours ago, bysouza said:
or lapic ou video problem
5 hours ago, moviemakergr said:
My friend i haven't Sound ..
Any solution ?
audio device id set to 70A10000 ?
  • Thanks 1
Yes my friend it is..
never mind.. i fix it now with VoodooHDA and to future we fixit again with Alc..
I don't want to tire you out for real reason. :)
Thanks again for your response.
after I replace with the DSDT.aml from you , the trackpad totally not working even in Catalina or bigSur
How can i rename the test-partion and  why it is not possible to boot into recovery-mode?
EDIT: Also verbose-mode doesn't work for me.
Edited by JaoM
Ok...renaming the "Test" called partition works in terminal with diskutil. In this example, i've renamed from "Test" to "macOS Big Sur" with the following command:
sudo diskutil rename "Test" "macOS Big Sur"
I now still need a solution for the recovery- and verbose-mode.
EDIT: Renaming does not really work - need further access to recovery partition for this :(
Edited by JaoM
  • Thanks 1
I am going mad i have tried to restore multiple times and i am encounting this error
dd: /dev/disk3 of=/dev/disk0 bs=32m: No such file or directory
I have tripled check everything and the disks are correct
Anyone some help ?????
post one dump here with ioreg. i'll check
reset nvram first time
something wrong. check procedure with calm, step by step
Thank you, the problem with the verbose occurs everytime after i've booted from an other EFI - so before booting the EFI for Big Sur, i must always do the nvram reset again.
Do you know, what the problem with booting into recovery-mode could be? This still doesn't work.
i think don't work for now. need wait bootloaders devs
On 6/27/2020 at 4:07 PM, Abbas Mohammed said:
btw anyone tried on clover?
Yes, some guys tried to run Big Sure on Clover Bootloader following the instructions on that page:
https://www.hackintosh-forum.de/forum/thread/49311-macos-11-bigsur-dev-beta-clover-patch/
And using this kext injection package:
https://www.hackintosh-forum.de/attachment/144558-bigsur-clover-kextinjection-package-zip/
Those guys actually got BigSur running on clover yesterday:
9 minutes ago, MaLd0n said:
Have all here
Sucesso! Já estava rodando o BigSur no meu Lenovo S145-15IWL, usando sua EFI do OpenCore e o DSDT.aml que vc postou aqui:
Posso usar o mesmo DSDT?
Se não for pedir muito, vc poderia atualizar o post 1 do tópico https://www.olarila.com/topic/9022-the-real-vanilla-hackintosh-with-macos-bigsur-and-opencore-full-dsdt-patches-notebook/ incluindo também uma cópia da pasta EFI do Clover? (Assim já facilita pros outros usuários do S145 que, assim como eu, são fãs do clover mas manjam quase nada de OpenCore.. rs)
mais tarde faço isso
Same here:
Error: https://drive.google.com/file/d/1wjaB9Z05wc_GzXQuQiwbg1rcUzjcAlz-/view
EFIhttps://drive.google.com/file/d/1LxtyOaRqLTl6bdnnxzQjdxVbU6cp0q1p/view
MacPro7,1: Huananzhi 2.49pb | Intel Xeon E5-2690 v1 | 64 GB RAM | Gigabyte RX 590 | Opencore 0.6.5 | KingSpec NVMe SSD (Big Sur 11.1) | Samsung SSD 860 EVO (Windows 10) | Fenvi T919 (BCM94360CD) | Apple Magic Keyboard 2 | Apple Magic Trackpad 2
