7 hours ago, MaLd0n said:
With this DSDT, BigSur still get stuck on USBEnumeration.
Catalina reboots with this.
Maybe you have another Idea.
Thank you
9 hours ago, HUYNH ANH said:
Sorry, you can't view or download this file at this time.
many downloads
9 hours ago, Kankon said:
iMassage work now
extract one ioreg
4 hours ago, Life Ok said:
thank you for your hard work
Enjoy!
4 hours ago, gaule said:
Can you please kindly fine tune my DSDT. As always much appreciated for your help and hard work
3 hours ago, hwp_2804 said:
Trackpad : ELAN0650
i need one full dump, not only efi
no idea. work for all. idk what happens in this case. ;)
2 hours ago, rositaott said:
Hi @MaLd0n, sending you my new sendme for BigSur...thanks in advance ?
remove ssdt olarila and add dsdt, need add entry in config.plist too
1 hour ago, MarceloMustaine said:
tem como me ajudar Maldon? valeu!
vc tem de extrai com o opencore, não clover
1 hour ago, hwp_2804 said:
@MaLd0n here's are the full DSDT dump , inside the ACPI folder
1 hour ago, Kankon said:
extract  : you mean  this file or u need something  from IORegistryExplorer ?
u talking about built in wifi? intel?
Yes
my motherboard : https://www.asus.com/Motherboards/TUF-Z390-PLUS-GAMING-WI-FI/
Intel® Wireless-AC 9560
Wi-Fi 802.11 a/b/g/n/ac
Supports dual band frequency 2.4/5 GHz
Supports 2x2 MU-MIMO
Supports channel bandwidth: HT20/HT40/HT80/HT160
Edited by Kankon
Motherboard Asus TUF Z390-PLUS GAMING (WI-FI) CPU 3.6 GHz 8-Core Intel Core i5, Ram 32 GB 3000 MHz DDR4, Graphics : AMD Radeon RX 6700 XT 12 GB OS:MacOS Tahoe 26.0 RC (25A353) SERIE 30, 40 (COOFFELAKE / COMETLAKE
Yes
https://www.olarila.com/topic/8390-no-more-dongle-use-intel-wifi-driver-loader-kext-tested-on-catalina/
49 minutes ago, Sic Mundus said:
I had everything working including the Intel Wifi but not my touch screen.
404 ERROR
4 hours ago, MorenoAv said:
Tudo funciona, apenas o boot está mais lento, mas também não importa...
vc tem de dar um rebuild cache. o boot é pra ser mais rápido
3 hours ago, Sic Mundus said:
Hello @MaLd0n and Guys,
this folder is not good. many renames etc
1 hour ago, gugadj said:
Ola @MaLd0n poderia rodar pra mim uma DSDT desde ja te agradeco
dsdt é o mesmo
32 minutes ago, Kankon said:
by the way the application textedit not working
is a bigsur bug, next release things start back to normal
On 6/27/2020 at 1:01 AM, MaLd0n said:
1
Good afternoon @ MaLd0n. I restored the image using Your method to an external USB disk, but when you start it in the OpenCore menu, it is not visible, as well as the disk with Windows, maybe you need to make some settings in the config to make the disk visible?
Edited by brumas
Dear @MaLd0n you are my last hope! I used Clover, but for Big Sur I made OC, all work with Catalina. (I changed HFSPlus.efi to HFSPlusLegacy.efi, and add VoodooTSCSync.kext because didn't boot without it).
I made a new one OC (0.6.0) for boot installed BS (from your manual at top.) but it didn't work with BS. I started delete speedsteps patches, dsdt, ssdt and else what can make fall, but nothing help. I use SMBIOS MacPro7,1 but for test tried imac19,1 - same bad resullt: Photo with trouble Catalina still boot with this OC. Added -lilubetaall - all the same. I attach EFI folder with very minimal pack for boot (without ethernet, working keyboard etc). Will be happy if you help me!
My specs: Huananzhi x79 2.49pb (B75 chipset), RX 590, Xeon E5-2690v1, NVMe Kingston A2000 250GB (full for BS)
EFI.zip
Edited by Frankovich
MacPro7,1: Huananzhi 2.49pb | Intel Xeon E5-2690 v1 | 64 GB RAM | Gigabyte RX 590 | Opencore 0.6.5 | KingSpec NVMe SSD (Big Sur 11.1) | Samsung SSD 860 EVO (Windows 10) | Fenvi T919 (BCM94360CD) | Apple Magic Keyboard 2 | Apple Magic Trackpad 2
hi @MaLd0n here's the file, hopefully this time is rights :)  Send me admin.zip
Edited by hwp_2804
