é muito difícil saber o que está causando isso, ainda mais sendo o bigsur
36 minutes ago, Roberto Collamar said:
I would like to have a Patched DSDT.
select rebase regions in acpi tab
Tentei usar o OpenCore no Catalina mas também deu o mesmo problema. Não demostra nenhum erro, apenas congela o boot =/
Já o Clover sobe normal no Catalina.
use o novo clover
https://www.olarila.com/topic/10934-guide-new-clover-bootloader-integration-quirks-configuration/
adicionaram as coisas boas do opencore no clover
format
post one photo in error screen
1 hour ago, robbyrc said:
hi maLd0n can you help me to fix or patch my DSDT, I try to dump in with windows or OC but can't fix 2 error like premature end-of-file and unexpected }
use it config.plist.zip reboot, extract new sendme
Hi Mald0n!
Could you create a custom DSDT for me?
My setup:
Gigabyte Aorus Z390 Pro
Gigabyte RX5500 8GB GPU / Soon: Gigabyte RX5700 XT
Intel i9 9900
BCN943602CS on PCIe adaptor (wifi not connecting)
Soon: Titan Ridge Thunderbolt Card
I booted my EFI from an external USB so the dumped EFI won't help I think.
I added my USB EFI that worked fine for booting with your aml to the USB folder (serials redacted)
https://easyupload.io/yu4aqv
I will donate :)
Thanks very much!
here we go DSDT.aml.zip
select rebase regions in acpi tab and remove ssdt olarila
2 hours ago, robbyrc said:
hope you can fix or mapping usb and fix sleep / awake too :)
https://www.olarila.com/topic/9390-video-guide-usb-port-mapping-with-hackintool/
  • Thanks 1
7 hours ago, robbyrc said:
Thanks maLd0n i will try it, may i know what patch that already you applied ?
common patches Olarila. essentials, cosmetics.
Thanks! Works perfect ?
Enjoy!
Enjoy!
Hi maLd0n, i got kernel panic after add dsdt to my OC
here's i take a photo : https://ibb.co/mSGnfLD
i try disable all ssdt except ssdt-plug but still panic at booting
