High fan speed while CPU is 42C (Skylake, Lenovo 700-15ISK)
Hi!
I'm having issues with my Lenovo 700-15ISK. My laptop's Fan Speed is relatively high besides my processor temp is at 42-45C. I'm using VirtualSMC and the temps are recognized, but the Fan Speeds are not (I can't change it or see it)
Is there a solution for it?
Here's the SendMe.app output (with your DSDT.AML that I'm using): http://s000.tinyupload.com/?file_id=78714931771370137444
On Windows, the fans are way less loud. Power Management is OK on Mac, the processor can scale down to 700MHz and can go to 3.5GHz.
Thanks a lot in advance!!!!
i think rehabman have one tread about it, check there
