snake881 Posted June 2, 2020 Posted June 2, 2020 Well I'm having issues when I try to turn on my cpu, always after I shut down and turn on again, when it's booting I get stuck, sometimes shows me the deny icon, or sometimes while it's booting gets stuck in the middle. So I always have to turn off my pc between 2 to 3 times to get to boot correctly. And when I hibernate the pc when I wake up again, the system get's laggy always and I must to reboot the pc to get working fine again.
Administrators MaLd0n Posted June 2, 2020 Administrators Posted June 2, 2020 post one dump https://www.olarila.com/files/Utils/RunMe.app.ziphttps://www.youtube.com/watch?v=k9wmIfGLe3A -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Consulting for macOS Hackintosh since 2006 HERE
snake881 Posted June 2, 2020 Author Posted June 2, 2020 2 hours ago, MaLd0n said: post one dump https://www.olarila.com/files/Utils/RunMe.app.ziphttps://www.youtube.com/watch?v=k9wmIfGLe3A Here is my dump from RunMe Send_Me_snake881
Administrators MaLd0n Posted June 2, 2020 Administrators Posted June 2, 2020 delete ur efi folder and paste new https://filebin.net/77bk735ccepjhis1/EFI.zip?t=a58x4uk8 1 -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Consulting for macOS Hackintosh since 2006 HERE
snake881 Posted June 2, 2020 Author Posted June 2, 2020 15 hours ago, MaLd0n said: delete ur efi folder and paste new https://filebin.net/77bk735ccepjhis1/EFI.zip?t=a58x4uk8 Right now I'm testing it, on the first boot after change de EFI folder I got kernel panic but I think it's because I did a rebuild cache in order to get right working. Just one question, I had my USB ports patched on my DSDT, and the ssdt was for my cpu, I got it with the ssdtPRGen method, and I had Microsoft folder on my EFI because was for my dual booting.
snake881 Posted June 2, 2020 Author Posted June 2, 2020 15 hours ago, MaLd0n said: delete ur efi folder and paste new https://filebin.net/77bk735ccepjhis1/EFI.zip?t=a58x4uk8 I tested it, and the boot is fine, the issues after wake up from a hibernate mode continues. and I still have the doubts that I posted recently. Quote Just one question, I had my USB ports patched on my DSDT, and the ssdt was for my cpu, I got it with the ssdtPRGen method, and I had Microsoft folder on my EFI because was for my dual booting.
snake881 Posted June 2, 2020 Author Posted June 2, 2020 @MaLd0n I was reading about OpenCore, you think that if I move to OC, will work better? Or should make a fresh install of Catalina and then install OC?
Administrators MaLd0n Posted June 3, 2020 Administrators Posted June 3, 2020 u can use clover or opencore, both work good -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Consulting for macOS Hackintosh since 2006 HERE
snake881 Posted June 3, 2020 Author Posted June 3, 2020 1 hour ago, MaLd0n said: u can use clover or opencore, both work good @MaLd0n ok really thanks, just one last thing, how can I use ssdtPRGen with my DSDT? because only works with kext
Administrators MaLd0n Posted June 3, 2020 Administrators Posted June 3, 2020 22 minutes ago, snake881 said: @MaLd0n ok really thanks, just one last thing, how can I use ssdtPRGen with my DSDT? because only works with kext u dont need it. ur processor have native support and u dont need down to 800mhz in iddle 1 -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Consulting for macOS Hackintosh since 2006 HERE
