On 4/7/2022 at 3:58 PM, MaLd0n said:
Hola Mate,
After doing a thousand tests with several Nvme, and M.2 SATA, none of them worked.
I came by chance to this post:
Possible incompatibility between new HP touchscreen laptops and KeySupport.
https://github.com/acidanthera/bugtracker/issues/1354
for these machines you have to use the Preloader.efi, and this solves the error of these machines. AT THE MOMENT IT SEEMS TO WORK ONLY WITH CLOVER.
Following the indications of some users, I confirm that I have been able to start Monterey and Big Sur from internal NVME Intel 660P with success, I used your EFI CLOVER, Lenovo IdeaPad S145 10th Gen IceLake HackBook, including the SSDT-OLARILA.am
I think this could be interesting information for everyone..!
I will now proceed with the fine tuning, as many functions of your Lenevo EFI no work on the HP Pavilion x360, but this I think will be a simpler task.
We continue with the work..!
Greetings
On 4/21/2022 at 6:05 AM, kahiser said:
Preloader.efi
3 hours ago, MaLd0n said:
Mate,
Could you give me a hand with the DSDT?
I leave here the Runme, so you have an example of how the EFI folder with the Preloader.efi loader looks like.
Send me MacBook-Pro-HP-Pavilion-x360
To make it start you have to create a manual entry in the Efi Bios of each machine and map the efi loader to make it work.
Maybe it will be useful in the future
Greetings
8 minutes ago, kahiser said:
Mate
don't use my dsdt from lenovo. ur notebook is hp. use olarila ssdt, reboot and extract sendme
On 21/4/2022 at 17:25, MaLd0n said:
no use mi dsdt de lenovo. tu portátil es hp. use olarila ssdt, reinicie y extraiga sendme
Hi Mate,
Did you have a chance to have a look at the sedme I sent you?
Thank you for your help
