2 hours ago, Paolo7297 said:
Hi, i have this kernel panic when going to sleep
u disable hibernate etc?
first run it
https://olarila.com/files/Utils/OlarilaRepair.app.zip
and post one full dump too
1 hour ago, MaLd0n said:
I tried after OlarilaRepair, but nothing changed..
RunMe app doesn't wanted to save ioreg (it pastes /tmp/send_me too fast) so i'll upload alone...
I'm not able to upload bigger files, so here it is: https://mega.nz/folder/zQ9HjBCZ#Dr9NTUWDxUZ-7BrcoEP2mg
My Desktop: CPU: i7-7700K, MOBO: Asus Strix Z270F, GPU: Powercolor RX5700, RAM: 16GB 3200mhz
Laptop: Model: Asus S512J-EJ051T CPU: i7-1065g7 GPU: Intel g7 / Nvidia MX330 RAM: 8GB 2666mhz
config.plist.zip
disable all ssdts
new ioreg after reboot
13 hours ago, MaLd0n said:
disable all ssdts
I have no brightness, but using remote control i was able to do everything.
Updated here: https://mega.nz/folder/zQ9HjBCZ#Dr9NTUWDxUZ-7BrcoEP2mg
EDIT: After a reboot i have brightness again... so there's something strange (sometimes happened before)
Edited by Paolo7297
yes. is a nvram problem or bootloader
devs need fix that in icelake ;)
The Sleep or the brightness problem?
2 hours ago, bimantoro said:
hi @MaLd0n can you share this folder again? i try this link is 504status
https://www.olarila.com/topic/5676-folders-for-all-chipsets-clover-and-opencore/
On 9/28/2020 at 10:38 PM, MaLd0n said:
hi @MaLd0n can u help me? i get in stuck begining of opencore, i use oc 0.6.1 with i5-10210U cometlake and NVme ssd.
this the stuck's image
https://ibb.co/NpMNk1C
(edit)
i have try your 10th gen mobile folder installer and success to installer menu but i can't find my NVme ssd, just my usb stick drive, what should i do?
thanks
Edited by bimantoro
strange. idk what happens
Hi @MaLd0n,
I'm running Catalina on i7-10750H notebook but it seems like i can't boot without USB. Even with USB i couldn't figure it out to run properly because it's really slow. When i try to boot from my HDD with your EFI folder (and i watched your opencore tutorial) it gives me this screen and reboots automatically. I know it says MacbookAir9,1 but i've tried MacbookPro16,1 and 16,2 too. Same error. Any help?
https://imgur.com/N7vRYwb
Edited by cengizhanunal
1 hour ago, cengizhanunal said:
Hi @MaLd0n,
use folder from usb
I'm new to this hackintosh, could you help me?
I'm trying in many ways to install the system on an M.2 SSD and always freezes the screen in the bootloader :(
what ur hardware? clover or opencore? last version?
Hello, first of all Thank you for this forum.. Really love it.
I'm trying to boot Catalina, it boots fine and runs the setup but the problem I'm facing is that when I run Disk Utility in setup it only shows me USB device and did not detect my internal SSD.
I'm using the following hardware.
Acer Predator Triton 300
Intel i7-10750H
16GB RAM
nVMe SSD - Intel Optane with RAID <-- This is my 1TB SSD.
4GB nVidia 1650Ti GPU
I'm using clover to boot.
Intel i7-10750H
16GB RAM
Hi.
Can you publish your EFI? One of my friends have a Triton 500.
thank you very much.
Hi @MaLd0n how it going ? I have a laptop Razer stealth 13' with an intel i7 1065g7 and im having a lot of problems I can't boot from your efi folder I get stuck in a very early stage (image: https://www.mediafire.com/view/nu1bl9w67tzejyz/ed5e5ad3-578e-4c36-bc4a-c8d5185cb49d.jpg/file) I have somehow made one folder that ether didn't  work but at least gives me a more of log (here is my folder: https://www.mediafire.com/file/8ywvv0fhjm2gpos/EFIbeta.zip/file) with efi folder im facing this exact problem: https://github.com/dortania/bugtracker/issues/17 can u give me some help?  as far I can understand its a problem with my usb, in windows I have tried al my USB ports which are HS01,HS02,HS03,HS04,HS10,SS01,SS02,SS03
