18 minutes ago, Dotun Adebowale said:
How do I add the config for HD 520, I was able to solve audio problem and I just discovered trackpad is missing. Thanks.
just add patch in devices/properties
Thanks for being patient with me, but I am confused, I am in device and properties but don’t know how to add the file in the zip folder I downloaded. Please I really need you to help simplify, thanks
send me ur config.plist
config.plist.zip
check Olarila folder for ur chipset and apply this patch
Quote
<key>PciRoot(0)/Pci(0x02,0)</key>
            <dict>
                <key>AAPL,GfxYTile</key>
                <data>AQAAAA==</data>
                <data>AAAbGQ==</data>
                <key>framebuffer-fbmem</key>
                <data>AACQAA==</data>
                <integer>1</integer>
                <data>AAAwAQ==</data>
                <key>hda-gfx</key>
                <string>onboard-1</string>
            </dict>
