boby55 Posted May 22, 2020 Posted May 22, 2020 For a few days now ive been trying to get uhd 630 to work, with just failure. I am still not able to get rid of 7mb error and i am not able to properly use integrated GPU. Ive tried multiple of guides on YouTube, using modified .plist files, kexts, and custom efi files, and i still haven't gotten anywhere. It just boots back into back into 10.13 like normal, still giving me the 7mb error. I use the normal default vanilla high sierra, but i also use the intel 10 20 30 notebooks chipsets efi folder over here for clover https://www.olarila.com/topic/5676-folders-for-all-chipsets-clover-and-opencore/ The model of my laptop is AN151-52. witch has an i5 8300h with has witch is coffe lake, and has a device id of 3E9B. The other specs being 16gbs of ddr4 ram, gtx 1050, 1tb ssd. Would anyone have a method of getting this to work?
Administrators MaLd0n Posted May 22, 2020 Administrators Posted May 22, 2020 https://www.olarila.com/topic/6420-guide-mobile-intel-hd-graphics/ -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Consulting for macOS Hackintosh since 2006 HERE
boby55 Posted May 23, 2020 Author Posted May 23, 2020 Thanks for the reply, but aren't these not for hd graphics? I tried the -HD620 and 630 10th and upon boot using your clover boot loader, it gives me error saying that osx isnt supported on this platform. However thats easily fixed just adding -no_compat_check under the args. And then im able to boot into the system. But once again when i boot into the system i still get the 7mb issue and im not able to use it properly.
versoCS Posted June 10, 2020 Posted June 10, 2020 On 5/23/2020 at 6:15 AM, boby55 said: Hello Boby55, i have same error in my hackintosh. I did, like you do, a lot any types the config, efi, etc and even so i always had some error. My processor is coffe lake i7 8700K 3.700, mobo Asus M-360M-K. You have trie change your symbios? Hello Boby55, i have some error in my hackintosh. I make, like do, any types the config, efi, etc and even so some error. My processor is coffe lake i7 8700K 3.700. You have trie change your symbios?
boby55 Posted June 23, 2020 Author Posted June 23, 2020 On 6/10/2020 at 1:50 PM, versoCS said: Hello Boby55, i have some error in my hackintosh. I make, like do, any types the config, efi, etc and even so some error. My processor is coffe lake i7 8700K 3.700. You have trie change your symbios? Sorry more less for the late reply. Simply , no. Ive tried multiple ways and tutorials and i keep getting the same issue. Im still waiting for a fix myself.
