premiere001 Posted May 2, 2020 Posted May 2, 2020 (edited) Helloo there, I have Installed Olarila High sierra on my Dell Optilex 3020. SPECS; Intel Hd 4400 Graphics RAM; 16GB Core i3 500GB HDD Everything else is working Fine Except my graphics. I am a film editor/Journalist and I really need to Change my Resolution to 1920x1080. I have Tried so many things ie using Switchrezx, Clover configurator(which I have very little knowledge about) etc. I am unable to make my Intel hd 4400 Graphics read right. It reads Intel HD 4400 3mb. Any help will be highly appreciated. If someone can configure for me my config.plist file, I will be very Thankful. I am Booting Using config.plist2 from Olarila High sierra. Edited May 2, 2020 by premiere001
Administrators MaLd0n Posted May 2, 2020 Administrators Posted May 2, 2020 https://www.olarila.com/topic/6420-guide-mobile-intel-hd-graphics/ -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Consulting for macOS Hackintosh since 2006 HERE
premiere001 Posted May 2, 2020 Author Posted May 2, 2020 (edited) Many thanks for the Incredible fast Reply. This Site is So awesome. Am gonna try this Out and See if it's Gonna Work. I am on desktop not Laptop. I am relatively new to Olarila and I have a Question; In my EFI Folder, there are two Config.plist files. One is named " Config.plist" and the Other is named "Config.plist2". I can only boot Using Config.plist2. In this case therefore, Do I replace the Config.plist in my efi with the on in the link U posted above for Intel HD 4400 and then Delete Config.plist2? Please give me a Procedure. Thank u in advance. Edited May 2, 2020 by premiere001
Administrators MaLd0n Posted May 2, 2020 Administrators Posted May 2, 2020 u try with InjectIntel only? -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Consulting for macOS Hackintosh since 2006 HERE
premiere001 Posted May 2, 2020 Author Posted May 2, 2020 Yes. I have tried with inject intel Only. The Result is that Everything Loads fines(the many codes that Run). But Immediately when it's time for the Apple Logo to Load (and then the Enter Password Wizard Comes Up), I Only Get a BlackScreen.
Administrators MaLd0n Posted May 2, 2020 Administrators Posted May 2, 2020 try with previous version virtualsmc and whatevergreen -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Consulting for macOS Hackintosh since 2006 HERE
premiere001 Posted May 2, 2020 Author Posted May 2, 2020 thank U 4 the reply. What do u exactly Mean by"try with previous version virtualsmc and whatevergreen". Do U mean i should I should delete lilu and whatever green from kext>other or just try with and then Put virtualsmc and whatevergreen previous versions in kext>other?
Administrators MaLd0n Posted May 2, 2020 Administrators Posted May 2, 2020 yes, dont use last version many people report many problems -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Consulting for macOS Hackintosh since 2006 HERE
premiere001 Posted May 3, 2020 Author Posted May 3, 2020 I have Used WhateverGreen1.1.7.RELEASE and VirtualSMC-1.1.0-RELEASE but I experience the same thing as i described above. What I did; 1. I dragged the whateverGreen and Virtual SMC Kext to EFI/KEXT/OTHER. 2. I Replaced the config.plist from the one in the HD4600, 4400 and 4200 zip file. 3. I then open this config.plist file with clover configurator and then check inject Intel. 4. I then Restart my Hackintosh. But Immediately when it's time for the Apple Logo to Load (and then the Enter Password Wizard Comes Up), I Only Get a BlackScreen.
premiere001 Posted May 3, 2020 Author Posted May 3, 2020 here is the Config plist i use. can U please do anything u can do to it to Help. I haven't modified it in any way. Thank u. HD4600, 4400 and 4200.zip
Arturo Miranda Posted September 18, 2020 Posted September 18, 2020 On 5/3/2020 at 5:13 AM, premiere001 said: here is the Config plist i use. can U please do anything u can do to it to Help. I haven't modified it in any way. Thank u. HD4600, 4400 and 4200.zip 2.73 kB · 10 downloads thanks!!! friend!!! works perfect H4400 in Catalina
