Hi, I would need to patch the DSTD. I send you the Runme of my team, and changed to Aorus Z390 Master, sorry for my English I am Spanish, thanks in advance.
A greeting.
Send me iMac-de-Vic1.zip
Edited by vic1
u have a full dsdt patched, the problem is other
Hello MaLd0n, thanks for your quick response, the problem is from the PCI-E 1X Wifi / Bluetooth adapter BCM943602CS to the internal USB header of the motherboard to power the bluetooth since I disconnect it and sleep without problem, is there any solution or put another adapter ,Greetings.
try put this port as Internal, create one injector with hackintool
I already tried, but it makes the same symptom does not sleep, however thanks for your help.
