Hello,
I have been trying to install Mojave on my system, it boots up and everything, I think I need help with Igpu or Framebuffer but not sure. I have seen many successful builds with the current config, and I would like to learn how can I achieve this.
Attached is boot.logboot.zip and config.plist.
My System Config:
Intel 3570k
Intel DH77EB
8GB DDR3
128GB SSD
Using HDMI Port.
Note: I am using Mojave from olarila followed the guide system is booting and Ethernet is working
Below is the Boot.log
config.zip
Edited by Kazi Murtaza Ahmed
try with InjectIntel
Inject Intel did not work.
so what I did is I did a fresh install again.
Olarila Mojave image.
and select Chipset EFI from the forum.
I managed to load framebuffer but now the screen is all messed up and I cannot read anything display over display.
below is the screenshot
attached is boot.log and EFI
EDIT:
I had given up and left the computer, I came back screen was black, but when I press a key on keyboard screen came back and everything was fixed?.. any suggestions what happened?
Hackintool reveals current info:
MACMINI 6,1
Ivy Bridge
0x0166000A
0x01628086
Intel HD Graphics 4000
boot.zip EFI.zip
Ok I was finally able to figure this out.
sorry to waste your time.
I had vt-d enabled hence the issue,
though in boot I had dart=0 which is still there, I believe that something to do with vt-d.
I also found this post on reddit which I believe helps
  • Don't use PluginType
  • Instead, drop the CpuPm and Cpu0Ist SSDT tables
  • You'll also want to generate an SSDT with Pike's ssdtPRGen.sh for power management
  • The resulting ssdt.aml can be dropped into the EFI -> CLOVER -> ACPI -> patched folder
    Implemented these as well not sure if they made any difference, I think they didnt.
    I have also attached the boot.log, if possible can you verify if everything is as it should be?
boot.log_2may.txt.zip
