Nackophilz1 Posted April 28, 2020 Posted April 28, 2020 (edited) Hello there ! I want to make an Hackintosh with this spec : CPU: 3900X GPU: 5700XT EVOKE OC MB: X570 Aorus Pro Wifi NVME: 970 PRO EVO 512Go -------------- So, first i tried to download the Olarila Catalina 10.15.4.raw.bz2 for AMD computer But there is two thing : - With the Bootloader included ( clover ) i got an error because of my 3900X ( CPU0 panic Caller 48 threads detected etc ) -> Seems to be a limitation because of Clover doesnt adapted for 10.15.4 - I tried to put the OpenCore EFI folder for AMD too -> Get the installation page , and i manage to erase my NVME and format to AFPS / GUID Partition -> So the installation begins and at like 2 minutes of the end , the computer suddenly reboot. -> I boot on my USB DRIVE again, and boot on my NVME on Mac OS Installer. -> Then i got an error on installation couldnt finish. ----------- I tried to edit my config.plist to adapt it to my configuration I tried to switch to EFI folder from other person with the approximate same configuration than me Nothing work at all The last update : I manage to launch the installation, and at 2 min of the end , the PC doesnt reboot, but stuck for like 20 minutes then he reboot suddenly and after booting on NVME same problem, installation problem etc ------------ If anyone manage ton install hackintosh on this config, can you give your EFI folder ? Or someone can help to handle that with me ? Edited April 28, 2020 by Nackophilz1
Administrators MaLd0n Posted April 28, 2020 Administrators Posted April 28, 2020 clover work good too u try my last efi with bootarg agdpmod=pikera? -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Consulting for macOS Hackintosh since 2006 HERE
Nackophilz1 Posted April 28, 2020 Author Posted April 28, 2020 3 hours ago, MaLd0n said: clover work good too u try my last efi with bootarg agdpmod=pikera? Hey ! Your last EFI Clover for AMD ? Include with the Olarila Catalina AMD ? Or another one ? And yes i Always do the agdpmod , but still with the panic 0 CPU caller with Clover ?
Nackophilz1 Posted April 29, 2020 Author Posted April 29, 2020 (edited) 11 hours ago, MaLd0n said: clover work good too u try my last efi with bootarg agdpmod=pikera? Hi again I try you last EFI CLOVER RYZEN ( from download page ) etc , same problem still have the error ''....panic 0 cpu caller 48 thread but 24 registered etc...'' ----- Also i tried too your Opencore EFI, but i can't get to the installer too, seems a problem with ACPI i dont get it exactly Edited April 29, 2020 by Nackophilz1
Administrators MaLd0n Posted April 29, 2020 Administrators Posted April 29, 2020 37 minutes ago, Nackophilz1 said: Also i tried too your Opencore EFI, but i can't get to the installer too, seems a problem with ACPI i dont get it exactly What problems with OC? -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Consulting for macOS Hackintosh since 2006 HERE
Nackophilz1 Posted April 29, 2020 Author Posted April 29, 2020 51 minutes ago, MaLd0n said: What problems He said there is a problem with ACPI file / Folder But i manage with mix with another EFI OC i found to install, but at 2 minutes remaining , the PC reboot , Then i try to boot on mac Os installer, and he Say an error occured , try to restart etc etc
Nackophilz1 Posted April 29, 2020 Author Posted April 29, 2020 (edited) When i try with your EFI OpenCore Folder only i got this error : Edited April 29, 2020 by Nackophilz1
Administrators MaLd0n Posted April 29, 2020 Administrators Posted April 29, 2020 create ur personal efi folder -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Consulting for macOS Hackintosh since 2006 HERE
