Sir , Thanks for nice Forum and support . I am actually newbie in Hakintosh . Few days ago I have successfully installed Catlina 10.15 followed by tutorial here . Almost everything are working , so I decided to extract ACPI for patching DSDT . But when I tried to extract it through RunMe app , its successfully extracted and saved in Desktop as zip . But later when I reboot Catlina , its won't boot .
The panic is - Memory panic stackshot succeeded.
Later I have to install Catlina again (cause I could not fix the error).
Then tried to extract by Clover F4 method now . This time also same panic again (stackshot panic) . I have to install full system again. Already I had installed Catlina 4 times ?
Chipset- Kaby Lake  ( Clover EFI used from forum this , and tried this also , both are fine to boot)
Processor- intel core i7
Memory - 8GB , DDR4
Graphics- Intel HD 620 (integrated)
I am using multi boot ( MacOSX , Linux, Windows)  through EFI boot loader.
Please sir suggest me how can I extract DSDT/SSDT without loosing system/data
Linux/Windows never affected by this problem .
Thanks.  If any other info I should provide please tell me.
Screen Shot 2020-04-25 at 12.00.03 PM.zip
use a correct folder, apply a video patch and embedded controller rename, reboot and extract one send_me
use olarila folder and enable ec0 to ec patch
2 hours ago, Zahid Islam said:
Won't boot . Installing OS again .
what? just drop
https://www.olarila.com/topic/5980-guide-drop-edited-dsdt/
yes
enjoy
