HP 8560w - i7-2820QM - HD300 installation issues - no graphics
Hi I tried installing High Sierra from the image, did't work, stuck waiting for the GUI too come up (profile 1 & 2). I then El Capitan similar issue, seems to boot ok but GUI does't come up, again tried config 1 & 2. This laptop has both HD300 and NVIDIA Corporation GF106 [Quadro 2000M].  Below is the device list. Any suggestions?
00:00.0 Host bridge [0600]: Intel Corporation 2nd Generation Core Processor Family DRAM Controller [8086:0104] (rev 09)
00:01.0 PCI bridge [0604]: Intel Corporation Xeon E3-1200/2nd Generation Core Processor Family PCI Express Root Port [8086:0101] (rev 09)
00:16.0 Communication controller [0780]: Intel Corporation 6 Series/C200 Series Chipset Family MEI Controller #1 [8086:1c3a] (rev 04)
00:16.3 Serial controller [0700]: Intel Corporation 6 Series/C200 Series Chipset Family KT Controller [8086:1c3d] (rev 04)
00:19.0 Ethernet controller [0200]: Intel Corporation 82579LM Gigabit Network Connection [8086:1502] (rev 04)
00:1a.0 USB controller [0c03]: Intel Corporation 6 Series/C200 Series Chipset Family USB Enhanced Host Controller #2 [8086:1c2d] (rev 04)
00:1b.0 Audio device [0403]: Intel Corporation 6 Series/C200 Series Chipset Family High Definition Audio Controller [8086:1c20] (rev 04)
00:1c.0 PCI bridge [0604]: Intel Corporation 6 Series/C200 Series Chipset Family PCI Express Root Port 1 [8086:1c10] (rev b4)
00:1c.1 PCI bridge [0604]: Intel Corporation 6 Series/C200 Series Chipset Family PCI Express Root Port 2 [8086:1c12] (rev b4)
00:1c.2 PCI bridge [0604]: Intel Corporation 6 Series/C200 Series Chipset Family PCI Express Root Port 3 [8086:1c14] (rev b4)
00:1c.3 PCI bridge [0604]: Intel Corporation 6 Series/C200 Series Chipset Family PCI Express Root Port 4 [8086:1c16] (rev b4)
00:1c.7 PCI bridge [0604]: Intel Corporation 6 Series/C200 Series Chipset Family PCI Express Root Port 8 [8086:1c1e] (rev b4)
00:1d.0 USB controller [0c03]: Intel Corporation 6 Series/C200 Series Chipset Family USB Enhanced Host Controller #1 [8086:1c26] (rev 04)
00:1f.0 ISA bridge [0601]: Intel Corporation QM67 Express Chipset Family LPC Controller [8086:1c4f] (rev 04)
00:1f.2 SATA controller [0106]: Intel Corporation 6 Series/C200 Series Chipset Family 6 port SATA AHCI Controller [8086:1c03] (rev 04)
01:00.0 VGA compatible controller [0300]: NVIDIA Corporation GF106 [Quadro 2000M] [10de:0dda] (rev a1)
01:00.1 Audio device [0403]: NVIDIA Corporation GF106 High Definition Audio Controller [10de:0be9] (rev a1)
24:00.0 System peripheral [0880]: JMicron Technology Corp. SD/MMC Host Controller [197b:2392] (rev 30)
24:00.2 SD Host controller [0805]: JMicron Technology Corp. Standard SD Host Controller [197b:2391] (rev 30)
25:00.0 Network controller [0280]: Intel Corporation Centrino Advanced-N 6205 [8086:0085] (rev 34)
26:00.0 USB controller [0c03]: NEC Corporation uPD720200 USB 3.0 Host Controller [1033:0194] (rev 04)
use -igfxvesa and nv_disable=1
Same issue, tried both config and config2, images attached showing boot args added and screen shots of boot and issue. Any other info I can provide?
Archive.zip
Edited by maccoylton
what sata option u have?
Extract tables with F4 key in Clover boot screen, files generated in Clover/Acpi/origin, post here
18 minutes ago, maccoylton said:
Now I get and ACPI Error scrolling continuously, on method [PPNT],  photo attached
apply a battery patch
Added SSDT-BAT from Rehabmans repo into patched directory. Fixed PPNT errors with this patch "into method label PPNT replace_content begin // nothing end;"  Now getting "broken text" and no entry sign as per attached picture
IMG_2270.jpg.zip
start again with patches
 ok .. it looks like  HD300 in the I7 has been disabled by HP.  No wonder I can't get it to start up. Will try again now will nVidia card
