My file is there : http://s000.tinyupload.com/index.php?file_id=04118955084394748852
Hello all,
Thank you very much for your hard work and the help you provide.
This is my build GigaByte Z370 Ultra Gaming 2.0 with BIOS 15a / 16 GB Corsair 3200MHz / i5 9600KF / NVME Samsung Evo Plus / Sapphire RX580 4GB.
I managed to install Mojave with standard unishit and an ACPI Patch because I had 1393 error when mounting APFS.
I did not use the EFI folders provided here.
multishit went well and now it is booting and sleep works. Intel Ethernet too.
But the Security update from Apple won't go through though. And There are some glitches when booting and after. USB and Audio do not work well.
This build will be used in production and needs to be perfect :) with all the features working.
I would appreciate any help to patch so it ends up as close to perfect as possible.
Thanks a lot in advance for any tip or help you could give me.
Stay safe, stay home.
Edited by ErnestBunbury
we dont support this tool here, is a big shit
use only my full efi folder into efi partition, only it, dont need install nothing(u need a fresh install, tony tools install many trashes into system folders)
EFI.zip
Enjoy!
Hi
Thanks for your help.
I changed my EFI directory for the one you provided.
But the update is still failing (Security Update 2020-002 10.14.6) it installs apparently ok but after reboot it is still offered as an update.
And the graphical glitches are still there.
Do you have any lead ? any idea ?
How can I get a log of all the error messages and warnings that appear behind the scene ?
7 hours ago, ErnestBunbury said:
Hi
boot again from update
6 hours ago, ErnestBunbury said:
Yes I did that. Tried multiple times. I did reinstall from scratch with your folder, then updated again. Reboot, update, reboot, update, etc.
delete folder into library/update, reboot and download again
I will, thanks.
I get many errors in the log, about ACPI, the Radeon card, etc.
Could you help ?
What do you need me to post here ?
extract new send_me
audio
idk about ur glitches
Enjoy!
