Graphics Acceleration UHD 610 Hakintosh Catalina does not work
After successful installation of Catalina, I can't get a graphics acceleration with the UHD 610 from intel. Appears in the Hardware information but only displays 5 Mb of VRam
Set-up
Motherboard Asus H310 gaming plus br
Processador intel G5400
Fonte corsair 500w
12 Gb ram ddr4 3200 balistix
Nvme 256 Gb kingspec
Hd Samsung 1Tb
MaLd0n, the pach informed in
it suits?
<key> PciRoot (0x0) / Pci (0x2,0x0) </key>
            <dict>
                <key> AAPL, GfxYTile </key>
                <data> AQAAAA == </data>
                <key> AAPL, ig-platform- id </key>
                <dados> CQClPg == </data>
                <key> id do dispositivo </key>
                <data> pT4AAA == </data>
                <key> framebuffer-fbmem </key>
                <data> AACQAA = = </data>
                <key> framebuffer-patch-enable </key>
                <key> framebuffer-stolenmem </key>
                <data> AAAwAQ == </data>
                <key> hda-gfx </key>
                <string> onboard-1 </string>
            </dict>
u can check a hackintool too, have many presets there
need check if ur igpu have support
Unfortunately it is not supported, only 620 and up. Despite not bringing any differences between them, I think the problem is restricted to the device ID.
Supported for. Sometimes look HP Pavalion x360 Covertible with a just Pentium Gold 4415U. No better choices in a price category with no stupid performance if know how it works.
