HP spectre x360 13 ap0007na - Less than a minute remaining of installer...
Hi,
 hopefully an easy one for you guys to give me some help with.
 Prepared the usb drive from the Olarila Catalina iso. Tried with config and config2.
 Boots into the installer ok, seems to install up to 2 minutes remaining then freezes. I then have to hard reset, and can access the installer from preloader... it then continues installing to less than a minutes remaining. Then freezes again...
can’t turn boot into Catalina. Not really sure on what steps to do next.
laptop is intel based. i7 8565u cpu, integrated uhd 620 cpu...
 Any ideas?
 Thanks,
G
use a full patched dsdt at installation and post installation
Hi @MaLd0n, thanks for that - Stupid question, how do I get a fully patched DSDT?
I appreciate it is probably well explained on here - a pointer in the right direction would be massively appreciated.
Edited by gilles beesley
