Alexander Wang Posted March 2, 2020 Posted March 2, 2020 ***I found this problem does not have anything to do with SMBIOS. This is because when I load the same SMBios that the flash drive gives the machine the Cpm does not work. ** Things I have tried. Dropped SSDT for CpuPM or CpuI0st. Imac 13,2 Macbook Air SMBIOS(what flashdrive loads on boot) Different Cpu management kexts, -xcpm 9010.zip I also tried mimicing the config.plist off the Olarila flash drive to see If that would work it does not. But I am so close. If I boot from Olarila Flash CPU management works but USB and other icloud breaks. If I boot from my config with different smbios etc CPU is still at 1.3Ghz max for Intel power gadget. Can someone compare my configs and see what I am missing from the 9010 that could be why it works off the Olarila flash. I will be more then happy to offer a writeup once its all working. Bluetooth: I have the IO gear USb dongle that works natively in Mojave. However it does not show handoff functioning. I have seen people make this work with different kext from Rehab man but when I loaded Brcm patch to the other kext folder there was no change? Is there a config change I need to make as well? config.plistOlarilaFlash.zip RehabMan-BrcmPatchRAM-2018-0505.zip
Administrators MaLd0n Posted March 3, 2020 Administrators Posted March 3, 2020 bt usb work without any injector, but some functions need a correct smbios i think with olarila usb ur pm don't work, if u inject a PM properties the problem appears -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Consulting for macOS Hackintosh since 2006 HERE
