mitexxo Posted March 1, 2020 Posted March 1, 2020 (edited) Hello, everyone. First I'd like to thank all of the Olarila community for an amazing amount of job put in here, as for the sharing knowledge through the so well explained/detailed guides and tutorials. I've been following MaLd0n's guide and managed to install and successfully boot High Sierra 10.13.6 on my SSD in the first try. Problems were expected and on my part - it was the audio. After reading and learning more, I managed to make it work - in the Clover, I loaded config.plist from my EFI partition (folders I put on my EFI partition are downloaded by MaLd0n's guide for my chipset), then I downloaded and installed Lilu and AppleALC in the Clover Kext Installer. After reboot, the Audio is working, but there is no internet/network. Do you know what could be causing this problem? Do I need to try a different Audio Inject layout? I left my on "1" by default after installing in the Clover because it was working. Here is my configuration: Motherboard: MSI P67A-C45 CPU: i7 2600 GPU: nVidia GTX770 16GB RAM ------------------------------------------- Thank You. Edited March 1, 2020 by mitexxo title
Administrators MaLd0n Posted March 1, 2020 Administrators Posted March 1, 2020 audio, try other layout-id what ethernet card? -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Consulting for macOS Hackintosh since 2006 HERE
mitexxo Posted March 1, 2020 Author Posted March 1, 2020 Hello, MaLd0n. O.K, I will try some other Audio layout-id... is it possible that it makes some confusion with network? My ethernet card is Realtek 8111E.
Administrators MaLd0n Posted March 1, 2020 Administrators Posted March 1, 2020 4 hours ago, mitexxo said: Realtek 8111E try other version https://www.insanelymac.com/forum/files/file/88-realtekrtl8111-binary/ -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Consulting for macOS Hackintosh since 2006 HERE
mitexxo Posted March 6, 2020 Author Posted March 6, 2020 I made it work, I just installed other version of AppleALC and now having both, sound and network :) Now I am just trying to figure out the bootloader and booting without USB.
Administrators MaLd0n Posted March 6, 2020 Administrators Posted March 6, 2020 2 hours ago, mitexxo said: I made it work, I just installed other version of AppleALC and now having both, sound and network Now I am just trying to figure out the bootloader and booting without USB. copy efi folder to ur efi partition -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Consulting for macOS Hackintosh since 2006 HERE
