Hi guys, so even though my DSDT is patched and my RX560 says Hardware acceleration is working it was having a hard time with 4k playback and sleep for longer then an hour is not working.
I am thinking Framebuffering and headless mode may fix it what are your thoughts?
is just a correct config, in this case, Mojave, only dgpu don't work good, need use via Intel Quick Sync(IGPU), both need work together
7 minutes ago, Alexander Wang said:
Is there a guide on this forum on how to read and correct config.plist files? I have seen a few websites on basics but I am not sure what should be on it that's not or vice versa?
is a same hardware in previous post? Ivy Bridge?
Yes
but with WEG and Lilu 1.3.4 nothing changed. So old and latest WEG nothing changes. Shinkivga=16 or 80 same result.
when i tried to play a 4k sample file it wouldnt play.
Edited by Alexander Wang
Yes
with old weg kext u can use shikigva=60 or any shikigva bootarg, i tested in many hardware, work good
config.plist.zipI have Injected Intel, WEG1.3.4 and used Shikgva 16,16,80 all same results. Will not play a 4k video. 4K video is just black. Will play 1080p fine but nothing else. You said correct config. Am I missing something?
u can try with iMac smbios instead?
Archive 2.zipAccording to Hacktool It say the Intel is disable. See files. Could this be a problem with my config. Even tho inject Kext is on. Only 32MB are stolen even though it say 1536MB Screen Shot 2020-02-23 at 1.46.19 PM.zip I have included Imac Config to see if that maybe helpful. I used imac13.2 smbios
I have included Imac Run me files too.
config.plist 2.zip Send me Axels-Mac-mini.zip
is wrong if appears here
in Graphics/Displays need appears only ur amd, intel hd appears in ioreg
Ok I have changed it in clover to be a headless I gpu. It calls it a Xeon Graphics accelerator. However It will not play back a 4k video that the real MAC will just fine.  Here is the test video I am trying to play. https://www.demolandia.net/4k-video-test/theater/page-1.html . Blue guy in the middle. My 2017 MBP plays it just fine.  In Quicksync if mine is working. it just plays a black screen. Before(IGP present in info) it would show a really laggy video with mismatched audio.
have some solution, take a shot
Quote
shikigva=32 shiki-id=Mac-7BA5B2D9E42DDD94
26 minutes ago, Alexander Wang said:
That was not enough but I found this https://hackintosher.com/guides/guide-to-fresh-installing-macos-mojave-on-a-hackintosh-10-14/ which helped get it working or at least the 4k video to playback.
How do you link images to where they show in the post? I have HTML, IMG tags but mine never show like yours?
u can test
just copy adress image with right mouse button and pste here
i'm using iMacPro1,1 or MacPro7,1 smbios for hardware accel without any injector or IGPU
1 hour ago, Alexander Wang said:
Is there a way to tell if I have 5.1 audio or a way to enable it?
i never use it, but work, some people use it, need check
2 minutes ago, Alexander Wang said:
My cpu is not running at full speed. is there something in the config that I am missing? it shows 3.4 GHZ on sys info but it only runs at 1.0GHZ to 1.2 at the most
in ur case need generate a ssdt for good power management
https://www.olarila.com/topic/6451-guide-generate-ssdt-for-power-management-with-ssdtprgen/
and drop CpuPm and Cpu0Ist OEM SSDT if need
"drop CpuPm and Cpu0Ist OEM SSDT if need"
The first part SSDT is already in patched. those 2 options are not buttons on clover config are they? Am I just deleting those tags in the ssdt?
5 minutes ago, Alexander Wang said:
I think IOreg is not seeing the SSDTs for PM.
check ioreg
looks good. generate c3, c6, for good pstates u need refresh some times
[img=https://i.imgur.com/mhKfWxG.png]
THat screenshot was after 3 different refreshes. Same with AppleIntelInfo.kext too. CPU still doesn't go past 1.3Ghz with a Chinbench test or any other cpu taxing program
