Hi i tried and use DSDT editor and patches and have no luck to get sleep. I have no bios option to enable S3. I'm not using nullCpm( i have speedstep, using imac 12,2) and sleepenabler(if i use sleepEnabler i get KP). Can anybody help me edit DSDT?
OS: MAc os: 10.6.8
Mobo: Asus P8h67 rev 3.0
CPU: i7 2600 (no K)
MEMORY: 4gb ddr3 1333Mhz RAm kingston
G. CARD: Gigabyte GeForce 8400 GS
everything is working fine ,except SHUTDOWN/SLEEP.
When i put computer in sleep,computer sleep for 1 sec then wake up but then again go to sleep. this is looping cca. 5 times
(screen is not working when tries to wake). Then computer is running but no sound/screen/keyboard shortcuts.
When i put computer in shoutdown, sleep for 2 secs than wake up and restart.
anyone can help?
I saw other people with this mobo and the same problem, but no one figured it out.
Do you see any "wake reason" in /var/log/kernel.log?
Thanks for helping.
Just find this in kernel log:
Jan 16 18:20:23 Snovich-Mac-Pro kernel[0]: Wake reason =
Jan 16 18:20:23 Snovich-Mac-Pro kernel[0]: System SafeSleep Wake
Jan 16 19:05:08 Snovich-Mac-Pro kernel[0]: Wake reason =
Jan 16 19:05:08 Snovich-Mac-Pro kernel[0]: System SafeSleep Wake
Jan 16 19:17:38 Snovich-Mac-Pro kernel[0]: Wake reason =
Jan 16 19:17:38 Snovich-Mac-Pro kernel[0]: System SafeSleep Wake
Jan 16 19:25:39 Snovich-Mac-Pro kernel[0]: Wake reason =
Jan 16 19:25:39 Snovich-Mac-Pro kernel[0]: System SafeSleep Wake
But find this in var/log/kernel.log
Jan 16 22:17:08 Snovich-Mac-Pro kernel[0]: Wake reason =
Jan 16 22:17:08 Snovich-Mac-Pro kernel[0]: System SafeSleep Wake
Jan 16 22:17:08 Snovich-Mac-Pro kernel[0]: Previous Shutdown Cause: 3
Jan 16 22:17:08 Snovich-Mac-Pro kernel[0]: USBF: 2430.722 AppleUSBEHCI[0xffffff8009dd9000]::powerChangeDone - waking from hibernation with some queue heads on the queue. UNEXPECTED
Jan 16 22:17:08 Snovich-Mac-Pro kernel[0]: USBF: 2430.724 AppleUSBEHCI[0xffffff8009fe4000]::powerChangeDone - waking from hibernation with some queue heads on the queue. UNEXPECTED
Jan 16 22:17:37 Snovich-Mac-Pro kernel[0]: hibernate image path: /var/vm/sleepimage
Jan 16 22:17:37 Snovich-Mac-Pro kernel[0]: sizeof(IOHibernateImageHeader) == 512
Jan 16 22:17:37 Snovich-Mac-Pro kernel[0]: Opened file /var/vm/sleepimage, size 4294967296, partition base 0xc805000, maxio 400000 ssd 0
Jan 16 22:17:37 Snovich-Mac-Pro kernel[0]: hibernate image major 14, minor 2, blocksize 512, pollers 5
Jan 16 22:17:37 Snovich-Mac-Pro kernel[0]: hibernate_alloc_pages flags 00000000, gobbling 0 pages
Jan 16 22:17:37 Snovich-Mac-Pro kernel[0]: hibernate_setup(0) took 0 ms
Jan 16 22:17:37 Snovich-Mac-Pro kernel[0]: PXHCD ResetControllerState - reseting saved status for 4 root hub ports
Jan 16 22:17:38 Snovich-Mac-Pro kernel[0]: System SafeSleep
Jan 16 22:23:03 Snovich-Mac-Pro kernel[0]: hibernate_page_list_setall start 0xffffff8049b0b000, 0xffffff8049b2b000
Jan 16 22:23:03 Snovich-Mac-Pro kernel[0]: hibernate_page_list_setall time: 97 ms
Jan 16 22:23:03 Snovich-Mac-Pro kernel[0]: pages 261692, wire 76570, act 98643, inact 2276, spec 223, zf 4233, throt 0, could discard act 12034 inact 3542 purgeable 207 spec 63964
Jan 16 22:23:03 Snovich-Mac-Pro kernel[0]: hibernate_page_list_setall found pageCount 181945
Jan 16 22:23:03 Snovich-Mac-Pro kernel[0]: IOHibernatePollerOpen, ml_get_interrupts_enabled 0
Jan 16 22:23:03 Snovich-Mac-Pro kernel[0]: IOHibernatePollerOpen(0)
Jan 16 22:23:03 Snovich-Mac-Pro kernel[0]: writing 181318 pages
Jan 16 22:23:03 Snovich-Mac-Pro kernel[0]: encryptEnd 7385d10
Jan 16 22:23:03 Snovich-Mac-Pro kernel[0]: hibernate_machine_init: state 2, image pages 152431, sum was 345af15d, image1Size e4bba00, conflictCount 2, nextFree 75
Jan 16 22:23:03 Snovich-Mac-Pro kernel[0]: hibernate_page_list_discard time: 24 ms, discarded act 12034 inact 3542 purgeable 207 spec 63964
Jan 16 22:23:03 Snovich-Mac-Pro kernel[0]: IOHibernatePollerOpen(), ml_get_interrupts_enabled 0
Jan 16 22:23:03 Snovich-Mac-Pro kernel[0]: hibernate_machine_init reading
Jan 16 22:23:03 Snovich-Mac-Pro kernel[0]: PMStats: Hibernate read took 1858 ms
Jan 16 22:23:03 Snovich-Mac-Pro kernel[0]: hibernate_machine_init pagesDone 257806 sum2 1b93b1d8, time: 1858 ms
Jan 16 22:23:03 Snovich-Mac-Pro kernel[0]: Wake reason =
Jan 16 22:23:03 Snovich-Mac-Pro kernel[0]: System SafeSleep Wake
Jan 16 22:23:03 Snovich-Mac-Pro kernel[0]: Previous Shutdown Cause: 3
Jan 16 22:23:03 Snovich-Mac-Pro kernel[0]: USBF: 2462.882 AppleUSBEHCI[0xffffff8009dd9000]::powerChangeDone - waking from hibernation with some queue heads on the queue. UNEXPECTED
Jan 16 22:23:03 Snovich-Mac-Pro kernel[0]: USBF: 2462.885 AppleUSBEHCI[0xffffff8009fe4000]::powerChangeDone - waking from hibernation with some queue heads on the queue. UNEXPECTED
Jan 16 22:23:13 Snovich-Mac-Pro kernel[0]: systemShutdown true
Try to apply this patch to your original DSDT: http://Olarila.com/Packs/Asus/P8H67.txt
Thank You, DSDT patcher find 18 erorrs, but i click fix it.. DSDT is working, but didn't fix problem...
Hope that one day will work. But i tried different DSDt patches and some patches are close to sleep because led on desktop computer blinking(sleep mode), i will try some more patches. Thanx for Help.
Would you share these patches?
I tried patched dsdt from here: http://www.tonycrapx86.com/viewtopic.php?f=14&t=22528 .
(When put computer in sleep-led is blinking, i dont know which patches were used)
Ok I managed to get shutdown correctly- You must disable all usb3 support. (But seems that Mac find USB high-speed bus)
And When i put computer in sleep didn't wake up automatically. But when i tried to wake up, did wake with no screen support and usb... i look to the wake reason, seems the same...no reasons.
i also tried ubuntu 11.10, and the problem is the same like in mac os. Asus said that bios is in suspend mode s3/s4.
