Help: Stucked right at initial Olarila Mojave Boot
Hi all,
I'm a newbie in Hackintosh. Prior to this I managed to successfully install HS and M via tonycrap method but since many users are recommending Olarila/Vanilla so I decided to jump into it. I know it will take a while for a newbie like me to understand and successfully build my own Hackintosh, but I know I will get there.
Since this is new to me, I decided to use some old parts I have lying around. I will spend on new hardwares if I feel comfortable/confident building a Hackintosh soon. For now, I'm using just this old stuffs.
Asus Sabertooth P67
i5 2400
Geforce 210
8GB 1600mhz RAM
256GB SSD
Intel 82579 Gigabit Ethernet
Intel HD Audio via Realtek ALC892 with 8-channel support
Boot loader: new Olarila Mojave.app
I followed the guide in this forum in building the USB stick via Balena, everything was good. I pop the USB stick in, set default optimised on my BIOS, and all the misc settings as recommended. It booted up into Clover, select the installation option, and it got me to this prompt. I can't get to anywhere after this. LOL! :lol::evil::roll:
At the black screen:
Start
Start OSname
End OSName
Start InitDeviceTree
Please help, what is wrong! :)
ur gpu don't work under Mojave, stay in High Sierra
if u need a Mojave or Catalina, need use drivers from High Sierra
I was thinking of that too as I have just downloaded Olarila HS and rebuilding my USB boot. Thanks for the prompt reply! I didn't expect a reply so prompt. $$$ :guitar
By the way, do I need to take note of any settings both in BiOS and Clover options when I do the initial boot? thanks again!
By the way
u need boot from legacy, i think ur mobo is not uefi
use InjectNvidia
Oh... I was able to boot UEFI with both Tony and Vanilla. In fact I managed to install Sierra, HS and Mojave previously. So, do I need to do legacy? I don't mind trying both actually...
This is my first attempt to go via Olarila way which I think I will use Olarila moving forward (I need to learn and get used to the process though). Noted on InjectNvidia <--- this option is from the Clover option page right?
if u use a tony way, use all kexts into clover/kexts/other and not into library/extensions
Noted on that. I want to go 100% Olarila way, can help me point a link to where I can find all the necessary KEXTS?
Already loading Clover verbose...
Why does it take so long to clear these lines... I had this previously too. but it would eventually complete and get to Mac OS installation page... its still loading something and now at: kext stall[1], (240s): 'AppleACPICPU', 'AppleACPICPU', 'AppleACPICPU'
' Unspoorted CPU
' Unsupported CPU
' Uncupported PCH
' kext stall[0], (240s): 'AppleACPICPU', 'AppleACPICPU', 'AppleACPICPU'
' kext stall[1], (240s): 'AppleACPICPU', 'AppleACPICPU', 'AppleACPICPU'
I managed to complete HS installation! Now following through the guide you wrote post installation. I hope I can get it done soon, though I expect the unexpected but it will be good to know and fix.
2 questions, I am thinking of changing the graphics card, not so advanced as I'm not doing graphics or video editing and no games too. But, I need 3 display output, which graphics card would you recommend?
Thanks!
for high sierra u can use gtx 1050 nvidia with we drivers
Guest Mad axeman
Unplug the battery and install it that stops the start os errors
