Hi.
If my hackintosh boot on macpro 6,1 smbios everything works fine but if boot on imacpro 1,1 smbios the moetherboard usb's doesn't work.
I need imacpro smbios because I often use some software like wirecast and videoproc and it uses gpu hardware acceleration, those softs doesn't work properly on macpro smbios.
Can anything be done to solve the usb problem on imacpro smbios?
I use your X79 efi folder.
Specs:
Gigabyte X79-UD3 mobo
Xeon 1620 v2
Radeon RX480
Catalina 10.5.2
Thanks for your excelent work.
David.
Xeon 1620 v2
Radeon RX480
Catalina 10.5.2
use correct smbios and shikigva=128
