[HELP] Intel UHD 630 - HDMI and DVI no signal, only VGA works
Hello,
CPU: i7-8700
Motherboard: Gigabyte B360M-DS3H
iGPU: Intel UHD 630
OS: macOS Catalina 10.15.2
When I try to boot macOS with HDMI or DVI ports I get black screen, but if I use VGA port it boots succesfully and QE/CI is also working. I tried to use Hackintool to make HDMI and DVI works but didn't get it, don't know if I should do any different step or something, I've tried everything. I attached my EFI.
Thanks!
EFI: https://drive.google.com/file/d/1u-nggLN8w5lpdDwlHOCsQQ4wCQuwAEry/view?usp=sharing
This is exactly the same as the tonycrapx86 tutorial. Don't know if I'm doing anything wrong but does not works.
I've also tried the config.plist from this link: https://Olarila.com/forum/viewtopic.php?t=10299 because is the same motherboard and same problem, also with his Bus ID, Type etc and doesn't work.
Thanks!
This is exactly
check Menu/Patch/SystemConfigs for some presets
Tried some presets and didn't work. Everytime when I try to boot with HDMI or DVI goes to black screen :wallbash
