Help with fine adjust in a Mojave (10.14.5) _ backlight control _ i2c trackpad/keyboard
Hi community.
I put a Mojave 10.14.5 (Olaria's tutorial) in a Dell Inspiron 15 3000, i15-3583-D3X. After searching a lot in web for the "fine adjustment", I found two clover's folder who partially worked for me:
This clover folder not function the touchpad, keyboard and percentage of battery.
This clover folder not function brightness control and multi touch gestures from touchpad.
I tried a lot to find some solution, copying some parts of archive config.plist from one clover folder to other and tried the voodooi2c to correct the touchpad, without sucess. I tried the rehabman backlightfix script, whitout sucess ( the SSDT-PNLF.aml make my screen turn black).
Please, can anyone give a way to try some other solution?
Thank you.
--Run_Me
RunMe.app
update ur kexts for last version
Thank you very much Mald0n.
I upgraded the kexts. Everything is ok, except the multi gesture of trackpad. I dont have scroll and two fingers touch (right button) in touchpad. Do you know what I should have do to enable at least the scroll?
extract new send_me
