losewin Posted January 18, 2020 Share Posted January 18, 2020 (edited) I thought everything is working but when I tried to connect another monitor while booted on one monitor, the second monitor is not being detected so I restarted the unit, but then after verbose logs, screens are on standby, keyboard is working while I tried to press the capslock, and the led light turns on. What could be the problem? Heres my send_me file https://drive.google.com/open?id=1fIEqI3xtc5ivO9kSV8-RwnMbDxqsb8jT DSDT.aml.zip Edited January 18, 2020 by Guest CPU: Intel® Core i5-9400F MOBO: ECS > H310CH5-M2 GPU: Nvidia GTX 750ti Link to comment Share on other sites More sharing options...
losewin Posted January 18, 2020 Author Share Posted January 18, 2020 I booted with 0x0306A0, under Graphics Injector -> Fake ID But still the other Monitor is not functioning. I use DVI. CPU: Intel® Core i5-9400F MOBO: ECS > H310CH5-M2 GPU: Nvidia GTX 750ti Link to comment Share on other sites More sharing options...
losewin Posted January 18, 2020 Author Share Posted January 18, 2020 i tried to change the SMBIOS to iMac14,1 then iMac12,1 but still no luck CPU: Intel® Core i5-9400F MOBO: ECS > H310CH5-M2 GPU: Nvidia GTX 750ti Link to comment Share on other sites More sharing options...
losewin Posted January 18, 2020 Author Share Posted January 18, 2020 As of now I disable the inject nVidia on clover and I got booted to the OS but it does not display or detect the other DVI port CPU: Intel® Core i5-9400F MOBO: ECS > H310CH5-M2 GPU: Nvidia GTX 750ti Link to comment Share on other sites More sharing options...
losewin Posted January 18, 2020 Author Share Posted January 18, 2020 I notice that there are only one slot detected. https://i.imgur.com/kjlVPW1.png' alt='IMGUR>'> CPU: Intel® Core i5-9400F MOBO: ECS > H310CH5-M2 GPU: Nvidia GTX 750ti Link to comment Share on other sites More sharing options...
losewin Posted January 18, 2020 Author Share Posted January 18, 2020 I already done updating the Whatevergreen.kext and Lilu.kext CPU: Intel® Core i5-9400F MOBO: ECS > H310CH5-M2 GPU: Nvidia GTX 750ti Link to comment Share on other sites More sharing options...
losewin Posted January 18, 2020 Author Share Posted January 18, 2020 Also once I booted with one Monitor then plugin the second monitor, the display just wen't to black screen, the screen wen't to standby mode CPU: Intel® Core i5-9400F MOBO: ECS > H310CH5-M2 GPU: Nvidia GTX 750ti Link to comment Share on other sites More sharing options...
losewin Posted January 18, 2020 Author Share Posted January 18, 2020 (edited) Finally got it work Specifying the VRAM base on the GPU RAM works also its Video ports I have a GPU RAM of 2047mb </dict> <key>Graphics</key> <dict> <key>BootDisplay</key> <integer>1</integer> <key>DualLink</key> <integer>1</integer> <key>Inject</key> <dict> <key>ATI</key> <false/> <key>Intel</key> <false/> <key>NVidia</key> <false/> </dict> <key>NvidiaSingle</key> <false/> <key>VRAM</key> <integer>2047</integer> <key>VideoPorts</key> <integer>3</integer> </dict> Edited January 18, 2020 by Guest CPU: Intel® Core i5-9400F MOBO: ECS > H310CH5-M2 GPU: Nvidia GTX 750ti Link to comment Share on other sites More sharing options...
losewin Posted January 18, 2020 Author Share Posted January 18, 2020 Sad to say that after I restarted the PC it back to standby monitor CPU: Intel® Core i5-9400F MOBO: ECS > H310CH5-M2 GPU: Nvidia GTX 750ti Link to comment Share on other sites More sharing options...
losewin Posted January 18, 2020 Author Share Posted January 18, 2020 Now its weird cause I still didn't remove the VRAM settings which is working, now I have to remove the other DVI connector then plugin it in after it is booted. hhmmm CPU: Intel® Core i5-9400F MOBO: ECS > H310CH5-M2 GPU: Nvidia GTX 750ti Link to comment Share on other sites More sharing options...
losewin Posted January 18, 2020 Author Share Posted January 18, 2020 Okay, it turns out that, the main DVI port should be the one being use upon booting, but when I boot then the second DVI is being used then the OS booting process will cause a standby mode on the screen.. hhhmm CPU: Intel® Core i5-9400F MOBO: ECS > H310CH5-M2 GPU: Nvidia GTX 750ti Link to comment Share on other sites More sharing options...
Administrators MaLd0n Posted January 18, 2020 Administrators Share Posted January 18, 2020 for nvidia use csm enable in bios/uefi -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Consulting for macOS Hackintosh since 2006 HERE Link to comment Share on other sites More sharing options...
losewin Posted January 18, 2020 Author Share Posted January 18, 2020 is there a way to change the DVI Port order? this happens only if I use UEFI Boot. CPU: Intel® Core i5-9400F MOBO: ECS > H310CH5-M2 GPU: Nvidia GTX 750ti Link to comment Share on other sites More sharing options...
losewin Posted January 18, 2020 Author Share Posted January 18, 2020 for nvidia use csm enable in bios/uefi Thanks for the hint. CPU: Intel® Core i5-9400F MOBO: ECS > H310CH5-M2 GPU: Nvidia GTX 750ti Link to comment Share on other sites More sharing options...
losewin Posted January 18, 2020 Author Share Posted January 18, 2020 The problem is I don't see the CSM option on this BIOS hmm. https://i.imgur.com/YEcdbpu.jpg' alt='IMGUR>'> CPU: Intel® Core i5-9400F MOBO: ECS > H310CH5-M2 GPU: Nvidia GTX 750ti Link to comment Share on other sites More sharing options...
losewin Posted January 18, 2020 Author Share Posted January 18, 2020 I see the CSM Configuration I have change the Windows and others to Manual But still does not work, it still booted on the wrong DVI Port instead of the first one https://i.imgur.com/ttzcTse.jpg' alt='IMGUR>'> CPU: Intel® Core i5-9400F MOBO: ECS > H310CH5-M2 GPU: Nvidia GTX 750ti Link to comment Share on other sites More sharing options...
